60 series interchangeable parts
From Fort Worth, Texas
I have a FS5W60A 5 speed with worn main drive and counter gears. Are these 2 gears interchangeable with the 60 series 4 speed?
jpg  60series.jpg (96.58 KB)
20677_5da13b48e6059.jpg 1600X900 px
Posted on: 2019/10/12 3:33
Re: 60 series interchangeable parts
i believe nothing is interchangeable with the 60A. The 60L is the 5-speed built from the 4-speed
counter gear is much longer in the 60A
* 32200-H9700 GEAR ASSY-MAIN DRIVE FS5W60A
* 32200-H7300 GEAR ASSY-MAIN DRIVE F4W60L,FS5W60L
jpg  F4W60_COUNTER.jpg (58.86 KB)
174_5da19a3d78c57.jpg 866X704 px
jpg  fs5w60a_gears.jpg (62.66 KB)
174_5da19a5094049.jpg 1024X432 px
Posted on: 2019/10/12 10:18
DD...would you know of any other gearbox that has interchangeable parts with FS5W60A?
Posted on: 2019/12/5 21:02
Yes the other A-series gearboxes interchange. Same length
For individual parts nothing is interchangeable with the 60A
Posted on: 2019/12/6 0:17
A little more information ... the 60A came 1980-1982 Datsun B310 (Datsun 210/Sunny). This is the regular shift-pattern five-speed (all the other five speeds are dogleg-pattern shift)
these 60A small parts interchange
* input shaft and mainshaft bearings interchanges with 60L 4-speed and 60L 5-speed
* input seal O-ring ditto
* output shaft seal ""
* snap rings
* thrust washers
* needle bearings
* syncro inserts, couplers & hubs (for three gears)
* reverse/idler bearing interchanges with 280Z
* shift lever plunger & spring same as 510
* reverse checker same as 280ZX
* shift rail checking parts same as FS460L
* synchros for the 60A *may* interchange with others but they have a different part number
These gearboxes interchange with the FS5W60A, direct bolt up -- use same clutch and same driveshaft, although the gearbox crossmember may differ
* FS5W60L dogleg shift pattern
* F5C56A dogleg shift pattern
* FS4W60 4-speed
* FS4W56A 4-speed
This one requires the B210 clutch disk and has larger output shaft
* FS5W63A
Posted on: 2019/12/6 21:25
Thanks for all that DD. I'll post over in the Classifieds and see if someone has a salvage FS5W60A and will sell the main drive and counter gears.
Posted on: 2019/12/6 22:41
