spark plugs?
Not too shy to talk
From hobart/tasmainia/Australia
is the gap ment to be 0.8 - 0.9?
Posted on: 2004/7/3 6:59
Re: spark plugs?
Factory spec: 0.7-0.8mm (0.0287 - 0.315 in)
You may find that the engine runs smoother with a 0.035 gap (9mm ?). That's what I run.
Posted on: 2004/7/3 7:10
Re: spark plugs?
Not too shy to talk
what kind of spark plug do u use?
Posted on: 2004/7/3 7:17
Re: spark plugs?
My engine is 100% stock, so I use the stock plug. See the Tune-Up article:
NGK BP5ES
NGK BP6E
others
Tune-Up Information
Posted on: 2004/7/3 7:27
Re: spark plugs?
From Castro Valley,CA USA
NGK BP5ES .050"/ 1.3mm gap
MSD 6al with blaster 2 coil
Posted on: 2004/7/3 7:58
Re: spark plugs?
Not too shy to talk
thanks guys ill try all that but i dont think it will help all that much because now i have this weird noise coming from the block i dont know what the heck it is but i would like to find out if anyone knows what it could be!
Posted on: 2004/7/4 10:18
Re: spark plugs?
From Christchurch. NZ
ohh, that doesn't sound too good, you should get that looked at
Posted on: 2004/7/4 10:28
Re: spark plugs?
Not too shy to talk
yeh i should shouldnt i it sounds real bad kind of a cliking sound
Posted on: 2004/7/4 10:48
