S13 front brake conversion
From melbourne
Hi
I have just completed a brake conversion on my 120y and have a question with regards to disc placement.
Instead of having then slip on over the studs which increases track by 8mm is it possible to have them in the factory position.
I can bore out the rotor hub diameter and slide them onto the hub. Can also drill and tap the rotor to bolt factory style and can add a turned up ring behind the rotor if it needs more thickness for the threads.
I guess all you would then do is add spacers behind the caliper bracket to strut face (thickness of hub flange)
Anyone see an issue with this method?
Only issue i see is possibilty of brake mounts to hit strut, will have to measure it before going ahead
Posted on: 2020/9/27 13:39
Re: S13 front brake conversion
From Las Vegas USA
Are you having fitment issues due to.the increased track width? The increased track helps the handling.
Posted on: 2020/9/27 18:32
I have the S13 brake conversion on 120Y struts on my ute. I believe the track increase can be avoided if you use the drum brake stub axle from a 1200.
Your process may work, but seems like a lot of extra machining. Best to not have to alter the rotor in anyway as they are a consumable part and you'll have to replace it as some point. Easier to be able to grab a stock new S13 rotor and throw it on when you need to...but hey if you've got access to a lathe it's up to you.
Posted on: 2020/9/28 5:12
1200/120y struts, 1200 drum hubs, and 17mm brackets job done
Posted on: 2020/10/3 10:38
Car free
