Short strut insert
From melbourne
Hi
Does anyone know which strut inserts i can run in my 45mm 120y front struts. Im looking at making coil overs using this kit.
https://www.performancesuspension.com. ... for-making-a-strut-into-a
And i need shorter inserts. I have read the wiki where n10 pulsar and vw golf insert are used but im having trouble sourcing them from parts shops and online.
Also the part number on the wiki dosnt seem to yield much results. Anyone have any new part number?
Thanks
Posted on: 2020/10/7 3:32
Re: Short strut insert
From Mordialloc Victoria 3195
I think the N10 struts ran out a few years ago.
supafatto is the one you need to chat to as to whats available today
dp
Posted on: 2020/10/7 10:07
keep it simple
From melbourne
Thanks i have sent a pm to supafatto.
Posted on: 2020/10/9 4:44
From melbourne
From Albury
From memory I think I used rear MR2 strut inserts . About 30mm lower and can get them as a Koni adjustable shock.
Posted on: 2020/10/10 10:41
From melbourne
Which year/ model mr2?
Did it fit in thr housing ok?
Posted on: 2020/10/10 13:31
From Albury
My memory is old and foggy but we used
Koni adjustable shocks 8641 1072sport
we cut 30mm out of strut leg and put the King lowered springs on them .
Top it off with camber adjusters and S13 brakes and we have a great front suspension at a reasonable price .
Posted on: 2020/10/11 0:34
From melbourne
I think i have found a part number for vw golf strut inserts for kyb.
From what i can gather the part number used to be kyb 361005 but i called up a auto parts place an that part number dosnt exist.
So i got him to look up a 1975 golf with the 1.6l engine and the part number that came up was kyb 363001
Can anyone confirm if that is the same part just new part number?
It seems available through auto part shops.
Posted on: 2020/10/14 10:55
From melbourne
Hi
So i called up kyb head office and confirmed the part numbers
Part number: 361005 is a american part number
Part number: 363001 is for australia.
They both share same specs with the outer diameters being 38.1mm so it should fit inside a 45mm strut.
I will update the wiki with the part number to make it easier for people in the future.
Posted on: 2020/10/15 2:19
363001 done fit the shock tube FYI
Posted on: 2020/10/17 14:01
Car free
