« 1 ... 3 4 5 (6)
Re: A15 turbo manifold build
From Adelaide
Livin' the dream! Great work. Looks like loads of fun.
Posted on: 2020/10/20 10:23
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Melbourne, Australia
Wow looks awesome.. and omg... Them turbo a-series noises.... So freaking cool
Posted on: 2020/10/23 23:26
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Mordialloc Victoria 3195
Hey M.
You'd be amazed at how quiet it its even with a 2 1/2" straight through muffler.
dp
Posted on: 2020/10/24 23:17
keep it simple
From Sydney, NSW
Just wondering where you sourced your steam pipe from and what specs it is?
Thanks very much
Posted on: 2020/11/11 11:01
Steam pipe bends I got from the local steel supplier. From memory they were only about $5 each.
I cant remember the spec - I just got the one slightly larger than the exhaust outlet size
and squashed it in the vice to make it a little more square.
dp
Posted on: 2020/11/11 19:03
keep it simple
From Adelaide
Forum member Sikyne built manifolds with both 1" butt weld fittings and 1.25" and (if I remember correctly) found no difference in power. A 1" steam pipe is closer in hydraulic diameter to the port size than the 1.25" and a contraction is less lossy than an expansion. You'll probably find the 1" a bit easier to package. I'm planning to use 1" and crush them square to match the ports, then port match to the head.
I've bought them from Drummond steel (north suburbs of melb) before and ordered them from Blackwoods. I've not found a source in the southern suburbs of Adelaide.
Posted on: 2020/11/13 10:48
The final dyno tune (Thanks Simon) the other day yielded 149 kw and 230n/m and its plenty Quick.
dp
Posted on: 2020/11/26 18:37
keep it simple
« 1 ... 3 4 5 (6)
