Gearbox drain and fillter plugs question
From South Africa, Bloemfontein
Hi All
So this weekend I drained the gearbox and diff oils. I struggled my butt loose to get the gearbox drain plug off but eventually managed using a pipe wrench which could grip the square plug nicely.
But before this I used a number 15 spanner which I eventually managed to bend to be more of a 16mm and also a adjustable wrench. this caused the bolt to be damaged on the square edges. can we still get these bolts somewhere or must I next time get someone to build up the edges with a tig weld and then just polish it square again.
jpg  20210529_080546.jpg (167.29 KB)
2412_60b341319f96b.jpg 597X967 px
jpg  20210529_080605.jpg (192.07 KB)
2412_60b3413e19e63.jpg 639X932 px
Posted on: 2021/5/30 8:39
1977 Datsun 1200GX
Re: Gearbox drain and fillter plugs question
I use a pipe wrench too. no need to "fix" it, just re-use it as is. If you want it to look pretty again, a new one can be purchased
Nissan 00931-10810 PLUG-FILLER TRANSMISSION $0.84. Nissan USA no longer sells it. On Ebay now
jpg  00931-10810.jpg (53.96 KB)
174_60b3749b74443.jpg 956X624 px
Posted on: 2021/5/30 12:18
By the way, that plug was used by Nissan from 1966 to 2001
* filler plug 4-speed & 5-speed
* drain plug 4-speed
i believe it is a standard pipe thread part (british thread or metric thread I do not remember)
* drain plug 5-speed uses a different part with metric threaded bolt & washer used by various Nissans including 510 and Patrol
Be careful when tightening. As you discovered removing it, it is all too often over-tightened. On the 5-speed this can crack the adapter plate. The 4-speeds don't have this problem as the drain plug goes into the stronger extension casting
Posted on: 2021/5/30 13:22
What also might have contributed to it is that the oil was never changed in 12 years time.
Done only +- 11000 km in that time frame.
Posted on: 2021/5/31 13:23
1977 Datsun 1200GX
