Gx and a12t, breathers
Hi can anyone tell me why the Gx and a12t used a reverse breather system compared to the normal a12?
Posted on: 2021/5/1 15:15
Re: Gx and a12t, breathers
It's a good question that ive pondered from time to time
For A-series engine, the PCV valve screws into the intake plenum. On regular A12S (single-carb engine), this valve has a hose to the block breather tube. But on the Twin-Carb engines (A12T and A12GX) the hose connects to the valve cover tube
my guess is it was done for convenience, easier to route the hoses that way to side-draught manifold and air cleaner. In any case it looks neater
How did the Austins with twin SUs route the breather hoses? Perhaps whoever designed the twin Hitachis used a similar layout?
I also wonder about the block breather. It has a metal gauze/baffle insert to help separate oil from the crankcase vapor. Would that work when the vapor is pulled from the valve cover instead of the block breather? I should have had a closer look at the GX rocker cover, maybe it has that built-in. The single-carb valve cleaners do not have a breather gauze but only a simple metal baffle
Block Breather Mesh
Posted on: 2021/5/19 10:03
Hi, yeah I've used a h89 head on an a12 an fitted the Twin Hitachi carbs, but connected it up as a standard a12 setup.Seemed to be getting some sludge on airfilter so maybe I best try the other way?
Posted on: 2021/5/31 7:17
