Wtb crankcase breather pipe
From Sydney, NSW
Hi all I'm looking to buy a crankcase breather pipe in this style
jpg  2546.jpg (87.16 KB)
12667_60d162799c584.jpg 640X480 px
Posted on: 2021/6/22 5:09
Re: Wtb crankcase breather pipe
From Snohomish, WA USA
Put a drag hose on it and plug your intake. You dont need to put that crap back into your cylinders. 👍
Posted on: 2021/6/22 5:20
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Sydney, NSW
I'll be running it to a catch can. We have to for engineering but I wanted that pipe to do a short section of pipe then an AN fitting
Posted on: 2021/6/22 5:24
Just use a section of 1" radiator hose.
I just plumbed mine into my exhaust. The exhaust flow sucks any blow by in the crank case out the tail pipe.
Posted on: 2021/6/22 6:32
'73 2 Door Sedan
How I connected mine to catch can was to REMOVE the pipe, and I used copper plumbing fittings with exhaust system sealer for set it in place. If needed later, it can be knocked out again, but will semi-permanently stay there
Benny tapped the hole with a M22 tap and used a screw in fitting
So the stock Datsun 1200 breather pipe is straight
This can be cut shorter and a rubber hose connected to a fitting. Can use the stock breather hose cut short and an AN fitting with adapter down to smaller size
many B210 & B310s have right-angle Breather Tubes
Posted on: 2021/6/23 6:51
