What's the going rate for a set of SU cores?
Not too shy to talk
From Eugene, Or
I found someone that has a set of SU's which have been sitting for some time. They are likely just cores at this point. What is the going rate for a set of SU's which likely need rebuilt?
jpg  SU.jpg (52.63 KB)
21562_60d4b706c61c3.jpg 900X675 px
Posted on: 2021/6/24 17:42
Re: What's the going rate for a set of SU cores?
Not too shy to talk
From Eugene, Or
The last set I bought was $200 for an L series.
Posted on: 2021/6/24 21:48
those are flattop Hitachis from a B210 (B110 used dometops/non-smog version). For more info see our tech article HTC. Rebuilding is easy, there are just some metal washers and some paper gaskets. If they are corroded/rusty its a much bigger problem
working pair 20 years ago $150, 10 years ago $200 ...
cores are $250/pair at ZTherapy
Rebuild is $750 + cores from https://www.ztherapy.com
SUs from english cars are cheaper, but the Datsun manifold either way is desirable. MAKE SURE THE special A-series THROTTLE LINKAGE IS INCLUDED
Posted on: 2021/6/24 23:21
Not too shy to talk
From Eugene, Or
Thanks! Very helpful!
Posted on: 2021/6/25 16:58
