will swap H165 3:9 for 4:11 Melbourne
From Mordialloc Victoria 3195
Just to fill you in. I need to put my TopGear LSD,(currently in a 4:11) into another diff because the hard facing on the teeth has gone . I have a spare mint condition 3:9 ready but the crown wheel is 2mm offset different from the 4:11 so it wont fit unless I got a 2mm ring machined up to fit under the crown wheel (not ideal)
Let me know if you have a mint 4:11 (commonly out of the ute) that you would swap for a 3:9
dp
Posted on: 2021/8/12 5:01
keep it simple
Re: will swap H165 3:9 for 4:11 Melbourne
From Armidale N.S.W
Ive got a H165 ute diff centre I would sell have to check ratio got whole diff but its missing bits.
Posted on: 2021/8/12 13:21
73 1200 wagon SOLD
Re: will swap my H165 3:9 center for 4:11 - Melbourne
Thanks 'Dats'.
I'll keep looking out for one in Melbourne (or Vic area) so I can visually check it first as well as saving on
postage of a very heavy item.
Cheers dp
Posted on: 2021/8/13 22:55
Edited by zigmondo on 2021/8/14 1:25:48
keep it simple
1 BUMP - THEN I'LL LOOK TO FACEBROKE
Sad to see content diminishing :(
dp
Posted on: 2021/8/25 5:59
keep it simple
From Albury
Hey Ziggy
I have got a few up here .
Will have a sort through tomorrow and get back to you
Posted on: 2021/8/28 8:50
Thanks Bob - All good now. Found another 3:9 with the right offset gears so its back to the diff guy
NB : Not all H165 Diff gearsets are the same !!!
dp
Posted on: 2021/9/2 23:48
keep it simple
