Flywheels & clutch functionality
From Seattle ,WA.
Im installing the new A12 engine to replace the A15 and the flywheel I had set aside and refaced turns out to be 35mm thick, the one I was running on the A15 was 28mm, apparently a A12 FW, also ran a engine plate 3.25mm & a standard ht bearing carrier 33mm, it had a problem with clutch disengagement so made a longer slave push rod, still never worked right. All coupled to a 60A 5 spd.
I had a brand new Exedy clutch & cover- man, it was hard to push! Planning on running the 28mm FW, standard carrier & no engine plate, sound right for proper clutch operation?
Wiki doesnt say anything about A15 FW's, were they 35mm thick?
man I hate posting pic's on this site, copied links from Icloud, didn't work. Wouldn't it be easier to be able to pull them direct from our computers or ph's and not have to off site host them....my rant
Posted on: 2021/11/8 17:11
Re: Flywheels & clutch functionality
From Gone to Maui
A15 uses the same flywheel as A14
Posted on: 2021/11/8 18:24
From Seattle ,WA.
35mm thick? Wiki says 30mm
Posted on: 2021/11/8 19:42
From Gone to Maui
Yes, A15 engine uses the A14 flywheel
Nissan Part Numbers (Japan Domestic Market)
* 12310-H7200 FLYWHEEL ASS'Y A14 -7909
* 12310-H7201 FLYWHEEL ASS'Y A14 7910-8010
* 12310-H8900 FLYWHEEL ASS'Y V A14S, A15 8011-
* 12310-H8910 FLYWHEEL ASS'Y A14S, A15 8011-
USA catalog shows same part numbers
The 30mm thick is just a measurement I took from a couple of A14s. Here is me measuring it
By the way, iCloud does not do photo hosting. If you have "shared" the photo, we can use the URL and go to iCloud to view the shared photo, but it won't show up on any other web site. for example:
https://share.icloud.com/photos/0OINLZz6mp0YhFCDiv2VyFW3g
You can post the photos directly from your phone or PC. Click the "Reply" button to get the Upload button. Your photo is small enough for Datsun1200.com (only 1536x2048 pixels) but the file size is large (1.22 MegaByte). So I used STGThumb to reduce the file size (it is still the same image size). On iPhone you can use ResizeMe! or whatever is the current resize app to get the file size to under 200,000 bytes
jpg  _IMG_5282.jpg (188.02 KB)
174_618a0551a7583.jpg 1536X2048 px
Posted on: 2021/11/9 5:21
From Gone to Maui
That being said it seems there is yet another size of flywheel i hadn't run across
which flywheel is 28mm? The one cast 'K24C' or the one with casting marks 'H', 'II', 'L.03'?
Your photos are 3-megapixel resolution. Had to change the quality to 20% but they still look OK
jpg  IMG_5277.jpg (98.43 KB)
174_618a109adaffc.jpg 1536X2048 px
jpg  IMG_5278.jpg (119.78 KB)
174_618a10bbd4895.jpg 1536X2048 px
jpg  IMG_5279.jpg (192.60 KB)
174_618a10c810678.jpg 960X1280 px
jpg  IMG_5280.jpg (91.60 KB)
174_618a10d72ed4c.jpg 1536X2048 px
jpg  IMG_5281.jpg (119.56 KB)
174_618a10e198316.jpg 1536X2048 px
Posted on: 2021/11/9 6:10
From Perth
Are you running a step in your flywheel for free clamp load....or are you running a Toyo clutch?
Dattos are usually flat
Posted on: 2021/11/9 9:45
From Seattle ,WA.
H-11 FE is the 28mm A12, K24C is 35mm off the A15. Doug in Portland confirmed 35mm of an A14/15 FW & a 28mm off an A12, he measured both so it looks like stock for A14/15 should be 35mm thick.
Both are stock FW’s , perhaps the step was milled into it by machine shop or by whoever modified the pilot bearing hole before me. I had the machine shop turn down the bushing so it’ll fit.
No Toyota FW, both Datsun.
Thanks for putting up the pics Dave , maybe I’ll figure out how to load them
Posted on: 2021/11/11 6:40
From Gone to Maui
thanks i update the specs
i seem to recall the 'step' (slightly raised area) is factory stock. But not needed as the first time them flywheel is resurfaced the step is removed. Unlike certain toyo clutches it is a very slight step
Posted on: 2021/11/11 8:11
From Seattle ,WA.
Funny but Rob at Action left the step on both FW’s , he also turned down the pilot bushing to fit the smaller hole on the A12 FW - tapped it right in, god knows why anyone made that a smaller ID???
Posted on: 2021/11/12 16:41
