(1) 2 3 »
A15 question
From Wamboin near ACT(canberra)
will a rebuilt standard 4 speed 1200 gearbox be strong enough 4 a worked a15 engine????, if not then wat would be good enough and how much am i lookin at 2 buy one????
Posted on: 2004/7/5 10:56
DAT10K
Gun metal 1200 ute, worked a15, sexy lil beast!!!
Re: A15 question
From T'ville
depends on how you treat it!
dumping the clutch and doing burnouts will kill the box quickly , but then that will kill most gearboxes
if you want a stronger gearbox find a '60 series box from an a14/ a15 powered car like the aussie sunny /78-'80
Posted on: 2004/7/5 14:36
Re: A15 question
If you never do burnouts and don't dump the clutch, there's a good chance it will break (mine did). Any transmission from a B210 or B310 will be strong enough (60 or 63 series).
Posted on: 2004/7/5 17:03
Re: A15 question
From Brisbane, Australia
No, go a celica conversion. 5 speeds and strength. I find the A15's flog the bearings out from loading the gearbox up too much. I have an A15 with it's 16th 'box attached sitting on my shed floor at the moment. At the time I started playing with A series I reasoned that it would be cheaper to swap a few gearboxes in than do the celica conversion. I was wrong.
Posted on: 2004/7/5 23:25
Re: A15 question
Not too shy to talk
From canberra
tommy,
my ute is the primered one you saw the day we went to the burnouts, it has a worked a14 in it, and i absolutely flog the arse out of it (lots of races and heaps of burnouts). it still has the a12 4 speed behind it and i havent had a problem yet. i had the standard diff in for a long time and it is still alright (i thought it broke but it didn't). The only thing i have really had problems with was i broke an engine mount. Stronger stuff would be nicer though...... hope this helps
Posted on: 2004/7/6 9:51
Re: A15 question
well i am thinkin of stickin with the stock 4 speed till it s#*ts itself and then i may start savin my pennys and lookin 4 a celica 5 speed. Who much would one of these cost and what else is needed 4 the conversion????
Posted on: 2004/7/6 13:34
Re: A15 question
From Melbourne, Australia
i reckon the 1200box willl take the abuse for a while at least, if you want to keep it cheap, just grab a 4speed out of sunny with the a14 in it, it is a stronger version of the same box, i am using one in my road car and it has survived the boosted experiences so far
Posted on: 2004/7/7 1:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: A15 question
Yep, a standard gearbox will live behind an A14 ... but not behind a stock A15. It might live behind a 'worked' A15, if it has less low-speed power than a stock engine. Remember, it's not horsepower that breaks things ... it is power/rpm aka torque (twisting force). The higher the rpm the power is made, the less twisting force it has. The lower the rpm the power is made, the more twisting force.
Posted on: 2004/7/7 4:21
Re: A15 question
From SE Melbourne
Extending this thread...are the gear ratios of the A12 4 speed the same as the gear ratios of the a15 4 speed.
Reason I ask is I have the choice between an A12, A15 4 speed. (A15 out of an Aussie Sunny) and the A12 out of a 1200 Coupe.
I was wondering if it was worth the trouble of using the A15 box......
Posted on: 2004/7/7 4:25
Mildman, Datsunless
Re: A15 question
Ratios are different for all of them:
56-series 4-speed
60a-series 4-speed
60L-series 4-speed
63-series 4-speed
I think the 1200 gearbox has the 'steepest' 1st gear, meaning the others are closer-ratio.
The standard gearbox is:
1st 3.757
2nd 2.169
3rd 1.404
4th 1.000
The 60L-series has at least two ratio sets:
1st 3.51
2nd 2.17
3rd 1.37
4th 1.00
1st 3.19
2nd 2.39
3rd 1.89
4th 1.00
Posted on: 2004/7/7 5:00
(1) 2 3 »
