Harada dual-carb intake manifold
KK Harada Shokai intake manifolds
https://www.jcy.co.jp/hrd/intake_new.htm
For weber/solex/dellorto $303 USD full kit from Greenline
* 1006 $380/$410 full kit
A12/A14/A15 oval port dual-carb
円ポート [elliptical (oval) port] ツインキャブ仕様 (twin carb specification)
* 1101 $410/$440 full kit round port
A型エンジン 丸ポート [A-type Engine maru (round) port]
原田商会 Harada Shokai 1011 インマニ inmani インテークマニホールド [intake manifold]
jpg  1006 oval port A14,A15.jpg (190.81 KB)
174_61f9e8cc5d98a.jpg 512X384 px
jpg  1011 round port (new bolt pattern).jpg (188.81 KB)
174_61f9e8d858729.jpg 512X384 px
Posted on: 2022/2/2 2:19
Harada round-port intake
Harada #1101
The Harada page shows it using the "New A12" bolt pattern
But see some drilled with center hole (dual pattern) to fit the old A12 and the New A12/A13/A14/A15 heads
The flange will also cover the water ports so it can run on unmodified 1980s heads
jpg  982_.jpg (41.94 KB)
174_61f9ecfaa0fc3.jpg 800X532 px
jpg  Harada 1101 Intake DSC_0945_zps93d0d2ad.jpg (102.85 KB)
174_61f9ed11d5b13.jpg 1024X680 px
jpg  Harada drilled for old bolt patten f398580660.1.jpg (35.66 KB)
174_61f9ed2c83aa8.jpg 600X450 px
jpg  f398580660.2.jpg (36.72 KB)
174_61f9ed6004b2a.jpg 600X450 px
jpg  f398580660.3.jpg (36.55 KB)
174_61f9ed724fc2b.jpg 400X600 px
Posted on: 2022/2/2 2:33
Re: Harada round-port intake
Looks like it has two vacuum bosses, one already drilled & tapped for a fitting, the other one not
OOPS, won't fit the 1200's cylinder head unless you drill a center hole in each flange
will it fit with the stock cast iron exhaust manifold? Or will it require tubular headers/extractors
eBay $665 dual-pattern version, including all the small parts so no scrounging, no accepting "kinda works" -- everything just works, including insulator gaskets linkage, fasteners
jpg  a round ports x2 DCOE.jpg (182.26 KB)
174_61f9fc0e8e7f1.jpg 1200X941 px
jpg  b shaft-type throttle linkage.jpg (193.96 KB)
174_61f9fc199dcc1.jpg 1200X1200 px
jpg  c vacuum fitting plug.jpg (192.59 KB)
174_61f9fc2672f77.jpg 1200X1200 px
jpg  d throttle cable.jpg (181.28 KB)
174_61f9fc2de830c.jpg 1200X1200 px
jpg  e new bolt pattern +old pattern.jpg (154.40 KB)
174_61f9fc558564c.jpg 1200X1200 px
jpg  f thick flanges.jpg (181.23 KB)
174_61f9fc6280d32.jpg 1200X1200 px
jpg  g heat insulating, vibration isolators.jpg (157.51 KB)
174_61f9fc8915c46.jpg 1200X1200 px
jpg  h insulator packing.jpg (143.02 KB)
174_61f9fc924afa5.jpg 1200X1200 px
jpg  i linkage.jpg (176.34 KB)
174_61f9fca187479.jpg 1200X702 px
jpg  j adjustable links.jpg (192.62 KB)
174_61f9fcab1bfb9.jpg 1200X981 px
jpg  k studs & nuts.jpg (186.82 KB)
174_61f9fcb3b3422.jpg 1200X1200 px
jpg  l nuts, flat washers , lock washers.jpg (137.99 KB)
174_61f9fcbc38a43.jpg 1200X806 px
Posted on: 2022/2/2 3:39
Like any DCOE-style inlet manifold, it accepts all the various carbies:
* Weber DCOE Carburetor
* Mikuni PHH (Solex)
* Dellorto DHLA
jpg  Mikuni-Solex on 1106 manifold DSC_0935_zps9645c43e.jpg (104.76 KB)
174_61fa1bca0d7a4.jpg 1024X680 px
Posted on: 2022/2/2 5:56
Harada oval port intake manifold
Harada #1006 dual-carb intake manifold for oval port heads
for standard A14/A15 oval port heads. Not for the extra-large GX oval ports
Bprojects used to sell this full kit with fuel hose even
Various Parts 各種インマニパーツ
* Various turnbuckles 各種ターンバックル
* Pillow balls for intake manifold インマニ用ピロバール
* New and old push levers 新・旧押しレバー
* Various fan levers 各種扇レバー
* Various return levers 各種戻レバー
* Standard product or one-off stainless steel 規格品orワンオフステンバー
* adjustment levers 調型レバー
* return springs リターンスプリング
* Various bakelite insulators & packings 各種ベークインシュレーター&パッキン
* car-specific intake manifold set 各車種インテークマニホールドセット
ベークインシュレーター 「ベークライト」
bakelite insulator for heat isolation (prevents vapor lock)
7-10cm thick
$20 to $30 set
jpg  1006 kit g48630066shakekun-img512x384-114118.jpg (37.16 KB)
174_61fa1ebc871a5.jpg 512X384 px
jpg  1006 kit g48630066shakekun-img532x600-114118.jpg (43.50 KB)
174_61fa1ed0e0e1e.jpg 532X600 px
Posted on: 2022/2/2 6:04
Re: Harada oval port intake manifold
These went for less than $200 each on auction but didn't come with all the parts
previous owner painted it black
the other one in natural aluminium
jpg  1006 with painted runners.jpg (139.96 KB)
174_61fa2328d6434.jpg 1200X900 px
jpg  1006 carb side.jpg (134.53 KB)
174_61fa2339e120f.jpg 1200X900 px
jpg  1006 head side.jpg (119.22 KB)
174_61fa234e75fa8.jpg 1200X900 px
jpg  p726595949.1.jpg (54.39 KB)
174_61fa2362309f7.jpg 1200X900 px
jpg  p726595949.2.jpg (59.62 KB)
174_61fa2370288f4.jpg 1200X900 px
jpg  p726595949.3.jpg (63.73 KB)
174_61fa23a37f917.jpg 1200X900 px
Posted on: 2022/2/2 6:24
on eBay now $665 + 40 shipping
100% brand new
Oval Port Intake Manifold Complete Kit
includes
1. x1 Intake manifold body
2. x1 Round drive shaft 295mm(Bar/Rod)
3. x1 Shaft stopper (include to drive shaft)
4. x2 Uniball 8mm-8mm metric thread (Support guide Pillow ball/Eyelets)
5. x2 Lever arm 40-60mm fit 8mm shaft (3 links)
6. x1 Accelerator wire holder 6.5mm (fan shaped)
7. x1 Bracket to hold accelerator cable
8. x1 Return Spring
9. x2 Ball joint link 95-100mm b/centers (Swivel ends)
10. x1 hose plug 8mm
11. x1 hose plug 14mm
12. x2 Insulator
13. x4 Insulator gasket
jpg  a Harada manifold.jpg (90.79 KB)
174_61fa29c8b79f8.jpg 1200X983 px
jpg  b Type 1006 Dellorto Solex Weber Intake Manifold Assy KK HARADA SHOKAI.jpg (104.69 KB)
174_61fa29d3a5250.jpg 1200X1200 px
jpg  c one threaded and plugged vacuum port.jpg (124.32 KB)
174_61fa29dd4ad32.jpg 1200X1200 px
jpg  d.jpg (91.67 KB)
174_61fa29ec2834c.jpg 1200X1200 px
jpg  e.jpg (101.77 KB)
174_61fa29fcdcc1e.jpg 1200X1200 px
jpg  f fan-type (quardrant-type) cable pulley.jpg (96.29 KB)
174_61fa2a06cbce7.jpg 1200X1200 px
jpg  g return spring.jpg (115.52 KB)
174_61fa2a126b045.jpg 1200X1200 px
jpg  h.jpg (94.65 KB)
174_61fa2a1f43d53.jpg 1200X1200 px
jpg  i fasteners.jpg (123.40 KB)
174_61fa2a29ca985.jpg 1200X1200 px
jpg  j turnbuckles.jpg (124.17 KB)
174_61fa2a43890ab.jpg 1200X730 px
jpg  k phenolic insulators.jpg (132.44 KB)
174_61fa2a4c39698.jpg 1200X1200 px
jpg  l.jpg (136.37 KB)
174_61fa2a5a01af6.jpg 1200X1200 px
Posted on: 2022/2/2 6:53
From Cambria, California
Jeeze Louise...I'd love to have this brand spankin' new oval port intake/linkage to replace my baling wire & duct taped old one, but my Mikuni carbs (40s) are not the identical twin versions that work with this intake/linkage, but rather the rarer mirror image carbs where the throttle shafts exit on opposite ends of each carburetor. Dang. Foiled again.
Posted on: 2022/2/4 1:11
