« 1 (2) 3 »
Re: Bumblebee
i've always had problems figuring out if it is fuel or ignition problems. hope it works out
Posted on: 2022/3/17 21:31
Re: Bumblebee
With the new plugs, new HT leads and carb cleaned.
I have managed to get the engine to now idle at 10 degrees @ 900rpm. Decent throttle response.
Once battery has been replaced I would be able to take it on the open road and play.
Road test is highway and driving up over the hill near me.
Posted on: 2022/3/24 11:30
Re: Bumblebee
Update! Its been awhile.
Swapping out bench seat for two Renault Kwid seats.
The adjustable rails had to go. The seats were too high with them in place. So I had to strip the seats down to the brackets.
I still keep the reclining function though.
I was able to use the existing bolts and holes in the chassis to bolt my frame in.
Moved the handbrake to the middle so I can stop impaling my leg every time I get into the cab.
Next on the to do list is swapping out the Chinese carburettor for a VW carb.
I am using a 5mm aluminium plate to fabricate the adapter for the carburettor.
I came across a nice set of 13 inch rims to give the bee some style.
jpg  seat.jpg (189.15 KB)
22474_62d51e425ddc2.jpg 2268X3024 px
jpg  existing.jpg (172.79 KB)
22474_62d51e90c7c40.jpg 3024X2268 px
jpg  frame.jpg (192.08 KB)
22474_62d51ea2068ae.jpg 3024X2268 px
jpg  frame2.jpg (178.22 KB)
22474_62d51eb20217b.jpg 3024X2268 px
jpg  handbrake.jpg (166.78 KB)
22474_62d51ed263d97.jpg 2268X3024 px
Posted on: 2022/7/15 20:58
Edited by Steversa on 2022/7/18 9:50:43
Re: Bumblebee
I didn't realize the break lever was on the side, but now i see it in the wiki photos
newer B140 (earlier 1980s photos show it in the middle)
Can you re-upload your photos? they are not showing up for me
Posted on: 2022/7/18 6:37
Re: Bumblebee
Images re uploaded to previous post.
This weekend I plan on bolting in the seats and sorting out the cabin.
Next on the list is to do the glove box fuse box mod. I have already moved the fuse box from right hand side to the left side.
Posted on: 2022/7/18 9:55
Re: Bumblebee
Yes the brake looks good between the seats. And looks painful when fitted on the side where you get into the cabin
I had to look up the Renault Kwid. I haven't seen a Renault in probably 20 years. The last one I saw was a Fuego, they stopped selling Renault in USA maybe 1987? They were always kine of rare but I still remember the Dauphine, the Renult 5 "Le Car" and the Alliance
Posted on: 2022/7/18 11:42
Re: Bumblebee
That is interesting. Keeping the French out the USA.
These small cars in South Africa are very common.
This is an example of the car the seats would of came out of.
https://zcw.co.za/listings/2017-renault-kwid-1-0-dynamic/
This weekend I plan on welding the studs for the drivers seat.
Posted on: 2022/7/19 6:48
Re: Bumblebee
That looks like a Nissan Juke, might be a shared Nissan-Renault platform
The Kwid seats seem the right size for a 1200/1400 and are sporty looking
jpg  2017-Renault-Kwid-1.0-dynamic-4-scaled.jpg (67.74 KB)
174_62d87fc99e5c1.jpg 800X528 px
Posted on: 2022/7/20 23:22
Re: Bumblebee
It has been awhile.
Seats are in and comfortable.
6 months ago I did a carburettor service and replaced all the gaskets. Fast-ward 5 months later and the gaskets are leaking and the accelerator pump 'boot' has perished.
So I weighed up replacing the carb with another Chineses copy or popping on the VW carb I had fresh in a box from my first car.
Swapped out the carbs and to make a custom accelerator cable bracket.
After a 120km road trip to work I was happy with going the VW carb route
I also have these babes to put on.
Still researching my tire options.
180/60/R13
175/70/R13
I Also need to replace the shocks as I am scraping the exhaust when going over speed humps.
Next is the installation of a gearlock so I can go to the shops with it.
Let me know if I need to re-upload the photos.
jpg  IMG_3191_2_15.jpg (155.91 KB)
22474_63ae8756ef54b.jpg 605X454 px
jpg  IMG_3192_15.jpg (146.87 KB)
22474_63ae876035e6d.jpg 605X454 px
jpg  IMG_4160_11.jpg (67.65 KB)
22474_63ae879d1fe1b.jpg 444X333 px
jpg  IMG_3761_30_45.jpg (134.09 KB)
22474_63ae88fc1123c.jpg 545X408 px
Posted on: 2022/12/30 6:36
Re: Bumblebee
unique mods there! Renault Kwid never knew existed.....
Posted on: 2023/1/11 14:57
« 1 (2) 3 »
