h190 rear axle 4 lug
hi anyone have a 4 lug h190 rear axle that could be shipped to the uk
Posted on: 2022/9/30 10:26
Re: h190 rear axle 4 lug
Sources:
* 1965-1966 Datsun 411 with R16 engine
* 1968-1970 Datsun Sports Roadster 1600/2000
* 1977-1979 Datsun 810 Bluebird/810 WAGON
* 1980- 910 Datsun Bluebird/Datsun 810/Datsun Maxima/Nissan Maxima SIX-CYLINDER WAGON
* C120 Vanette A15/A14 1980- A12 1985- Z20 LD20
* 1982-1983 Nissan/Datsun S110 Silvia/200SX has disk brakes
* 1984 Nissan S12 Silvia/200SX/Gazelle
If you can get an axle housing, then any H190 diff will bolt into it -- say a differential from a Datsun 320/520/620/720/D21/D22/Frontier truck. Some use different side gears, which can be changed to match the axles. As I recall, the one with the width most closely matched to the 1200 is the 411 SSS. The 320 Truck housing is narrower (!) than the 1200 housing, but it's a six-lug setup
Posted on: 2022/9/30 20:03
From Las Vegas USA
To clarify are you looking for the complete assembly or just the axle itself?
Posted on: 2022/10/18 20:48
