Browsing this Thread:   3 Anonymous Users
Solenoid Needle Seat in a B210 A12 Datsun 120Y Carbur
Hi:
Can the needle seat in the solenoid cavity, in a A12 B210 1978 Carburetor be extracted, and if so how?
Modifying a new A12 Carburetor for my stock 120Y. Thanks.
Regards
Beb07
Posted on: 2022/10/16 7:51
Re: Solenoid Needle Seat in a B210 A12 Datsun 120Y Carbur
yeah, just unscrew the solenoid from the carburetor and take out the 'pin' in the middle. Then re-install the solenoid. Start engine to see if all is well
It will no longer 'cut' the engine immediately when you turn the key off, but otherwise the engine will run well with this pin removed. The downside of removing this pin is that the engine may want to "run on" after you turn the key off. If this happens you can let the clutch out to stop the engine (keep your foot on the brake!)
The best way to fit a new-style carbie on an older car is to wire up the solenoid wire to the hot side of the ballast resistor. Then the solenoid works as designed
jpg  Idle Stop Solenoid.jpg (113.82 KB)
174_634c6a69ad2f8.jpg 1200X960 px
jpg  Solenod pin plunger.jpg (86.56 KB)
174_634c6a75012b1.jpg 1200X814 px
Posted on: 2022/10/16 21:14
Edited by ddgonzal on 2022/10/16 21:32:57
Hi:
i didn't describe it well enough.. within the carburetor body, within the solenoid hole, there is a metal circular sleeve that the solenoid needle sits in when attached. The new carburetor doesn't have this sleeve.. and the needle is loose..so .. l was wondering if that sleeve was being held inplace by something, as l am unable to get it out, or is it screwed in..
Regards
Posted on: 2022/10/17 2:43
Are you talking about the hole for the solenoid as in the photo above? or something entirely different?
Posted on: 2022/10/17 22:02
Hi
I have added some photos of the part in question...the old carburetor has the brass sleeve.. well i think its brass.. while the new one has nothing..
jpg  New1.jpg (145.80 KB)
20838_634f7f5dd3755.jpg 1840X2000 px
jpg  Old12.jpg (74.56 KB)
20838_634f804258e34.jpg 1455X1261 px
Posted on: 2022/10/19 5:43
thanks. i never looked at those. perhaps the new design doesn't need the brass insert. Is it one of those eBay China carburetors? Some of them work quite well
Posted on: 2022/10/19 10:23
Hi
Yea.. it is a chinese copy.. but the same caruburetor body, but with different attachments for the accelerator cable and the choke cable. So. l am modifying the carbie.. to fit the B210 1978. So, far so good.. but the solenoid is a pain.
Regards
Posted on: 2022/10/20 3:47
