Engine Mounts
Does anyone know of any companies selling polyurethane engine mounts for the 1200's? I did replace mine with aftermarket rubber ones a few years ago however the motor moves around a little too much for my liking.
Posted on: 2022/11/15 3:52
Re: Engine Mounts
yeah the stock rubber type allows a bit of movement, so as to damp out the 4-cylinder vibration
as far as I know no one makes poly versions of the B110 insulators. Several club members use round poly insulators which bolt right in place of the stock units
11223-H1000 INSULATOR-engine mounting
Poly insulators
Posted on: 2022/11/17 22:22
Re: Engine Mounts
From Las Vegas USA
I use a solid mount on one side and the stock on the other. Basically the solid mount is on the tension side.
Posted on: 2022/11/18 3:32
Re: Engine Mounts
A solid mount, as in solid metal?
I'm thinking the tension side is the right side, as Datsun engines (like most) rotate clockwise
Posted on: 2022/11/27 0:20
Re: Engine Mounts
From Las Vegas USA
Yes a solid metal mount.
Posted on: 2022/12/1 2:04
Re: Engine Mounts
From Las Vegas USA
Posted on: 2022/12/1 2:05
