Datsun "FLATTY" on Yahoo Auction
Datsun Flatty
860cc of pure simplicity
Im considering this for a motorbike
I have Kawasaki K1000 with no engine
that I could use with belt drive
has custom alloy head!!!! buyer also
supplies original cast iron head
This thing is too cute!!
jpg  D Flatty front.jpg (145.28 KB)
737_674ae0207bf28.jpg 688X688 px
jpg  D flatty side.jpg (90.42 KB)
737_674ae053769d6.jpg 580X580 px
jpg  D Flatty top.jpg (76.37 KB)
737_674ae062c0ca3.jpg 522X522 px
jpg  D Flatty back.jpg (60.22 KB)
737_674ae06c1d861.jpg 453X454 px
Posted on: 11/30 9:51
Re: Datsun "FLATTY" on Yahoo Auction
With that aluminum head, this is nicer than the other Datsun 860cc engines
And only $1000 https://page.auctions.yahoo.co.jp/jp/auction/o1161265037
Posted on: 1/8 11:45
sweet lil jigga, waiting for it to drop a bit
in price as I get 4X Yamaha fj1200 or Nissan FJ20
engines for that price :)
Posted on: 1/14 2:21
Some things i noticed about that flathead engine:
* I think the flat head says "着火 1243" [FIRE 1243], which is a different firing order than the modern 4-cylinders. Or is it? If the distributor turns in reverse, it is the same order, just in reverse
* It is fitted with an alternator, which does not match the 1950s type engine in the photo. Alternators weren't used until 1959, and not common until 1962-1964
* Is it an aftermarket head? All the ones I've seen before are cast iron, with the water outlet on top of the head. This one is much thicker, with water outlet on the side, and spark plugs sunk down from the top
* it has a floor shift transmission, which makes me think it is from a Datsun 110 sedan, which used an Austin 4-speed
It may be a Datsun D-10 engine (1952-964), 860cc -- 60mm bore x 76mm stroke. Very undersquare, as were most engines back then. With a 6:1 compression ratio it made 20hp. With a high-compression head, what do you think it made, maybe 30hp?
jpg  floor shift gearbox.jpg (155.00 KB)
174_678ae1c210aae.jpg 1200X901 px
Posted on: 1/17 23:08
