Exhaust
It's getting near impossible to find a replacement exhaust
New Old Stock (NOS) genuine Datsun muffler
Original mufflers came with integrated exhaust pipe - Top one is an aftermarket multi-piece type
Sedan/Coupe/Wagon differ
120Y muffler has a more severe upsweep but might fit the B110
jpg  B210 20100-H5000-1.jpg (13.46 KB)
174_69015e01097b9.jpg 600X160 px
jpg  20100-H5000-2.jpg (35.59 KB)
174_69015e0f76ada.jpg 600X450 px
jpg  20100-H5000-3.jpg (36.90 KB)
174_69015e1ee8e64.jpg 600X450 px
Posted on: 2025/10/29 0:23
Exhaust rubber insulator hangers
These factory parts make your exhaust absolutely quiet. With an original muffler, you couldn't hear the engine idling
Google search and japanese search
The muffler clamp RINGs and the hanging STRAP take all the vibrations out. Generic versions of these parts work OK
The rubber hangers have B10 Datsun 1000 part numbers
26030-18001 RING-rubber, muffler clamp
Early B210 to 1975 (including 120Y) looks the same, but as usual has an H50 part type, so they may be slightly different. Oh, by the way, when you get new ones, they seem too small. But they stretch to fit
26030-H5000 RING-rubber, muffler clamp 30x39mm inside diameter, 13mm diameter
Datsun 910/S110 Silvia and Nissan R30 Skyline/C31 use similar rings, but they are thicker (15 mm). Nissan 20630-N8200
Buy at Bprojects or https://datsun1200.jp
The strap (rectangular) rubber hanger uses M8 bolts and washers. It would be easy to make one, with some kind of heat-resistent material: 90x30x12mm with 2 M8 holes on 60mm centers. Or get one off a 280ZX, 810 Maxima, Urvan, Vanette, 240Z or 510/610/710 20640-18000
jpg  exhaust insulators.jpg (33.22 KB)
174_6901a1f013f44.jpg 600X354 px
jpg  C-231_106-1 Exhaust Tube.jpg (61.19 KB)
174_6901a2010130e.jpg 912X496 px
Posted on: 2025/10/29 5:17
Edited by ddgonzal on 2025/10/29 9:36:28
Edited by ddgonzal on 2025/10/29 18:03:56
Complete exhaust system
* The Muffler is located just in front of the rear axle, under the rear seat
* The body of the muffler is suspended by two rubber rings. When one breaks after about 10 years, the other one gets loose and just hangs around
* Coupe & Sedan have the same muffler location, only the bend shape of the tailpipe portion differs a little. This bend allows the pipe to go over the rear axle
* Tailpipe exits at the rear, below the bumper. Using a slightly longer tailpipe can help with fumes
jpg  DSC02595.jpg (93.06 KB)
174_6901a7f0815d3.jpg 1024X768 px
jpg  DSC02596.jpg (97.88 KB)
174_6901a80df2193.jpg 1024X768 px
jpg  DSC02598.jpg (107.13 KB)
174_6901a81e67333.jpg 1024X768 px
jpg  DSC02597.jpg (97.72 KB)
174_6901a825d8133.jpg 1024X768 px
Posted on: 2025/10/29 5:38
Exhaust tip
For sharp looks, you can fit a stainless extension which looks good forever. Needs to fit a 1.5 inch pipe, and while most aftermarket tips are larger they fit a range of smaller pipe sizes
or a cheaper chrome tip like this factory B110/B210 option, which looks fabulous for a few years
This is a vintage Nissan Muffler Cutter with part number 20321-H2500. It is a new old stock (NOS) part, meaning it is an original, unused part from a past production run.
* This type of part is often sought after by collectors and restorers of classic Datsun and Nissan vehicles.
* The packaging indicates it is a genuine Nissan part.
* The item is a chrome exhaust tip, designed to be fitted to the end of the tailpipe
jpg  20321-H2500 Muffler-Cutter マフラーカッター B110.jpg (52.91 KB)
174_6901d3b7e6a58.jpg 736X432 px
jpg  20321-H2500 stainless slip-fit exhaust pipe extension.jpg (58.20 KB)
174_6901d3c313043.jpg 767X1024 px
jpg  20321-H2500 slip-fit.jpg (59.36 KB)
174_6901d3d492c26.jpg 767X1024 px
jpg  20321-H2500.jpg (41.21 KB)
174_6901d3daa725a.jpg 767X1024 px
jpg  20321-H2500 Outside Diameter 36mm.jpg (80.73 KB)
174_6901d3f3f06af.jpg 767X1024 px
jpg  20321-H2500 I.D. 34 mm.jpg (92.09 KB)
174_6901d401929a3.jpg 767X1024 px
Posted on: 2025/10/29 5:48
Edited by ddgonzal on 2025/10/29 8:45:01
NOS muffler
There was one genuine Datsun muffler for sale on Yahoo August 2025. It had 8 bids and sold for 34 USD
It is a B210 part number, and looks identical to the B110 part, but is a little longer at 329mm (1-3/8" longer than B110). There is plenty of room in a sedan for this. It (conveniently) has the tailpipe cut off for storage and shipping
jpg  20100-H5000 Sunny 1200 NICHIRA muffler.jpg (131.99 KB)
174_6901cdb253e98.jpg 823X1200 px
jpg  20100-H5000 229mm long.jpg (143.06 KB)
174_6901cdee08dd2.jpg 1200X862 px
jpg  20100-H5000 ~205mm width.jpg (167.14 KB)
174_6901cdfbdb28f.jpg 979X1200 px
jpg  20100-H5000 band with RING mounts.jpg (146.34 KB)
174_6901ce10d5f84.jpg 1200X1003 px
jpg  20100-H5000 slip-fit to exhaust pipe.jpg (168.24 KB)
174_6901ce28606ac.jpg 1200X942 px
jpg  20100-H5000 tailpipe cut off.jpg (113.33 KB)
174_6901ce44482f5.jpg 1200X798 px
jpg  20100-H5000 top.jpg (135.70 KB)
174_6901ce5c8e001.jpg 877X1200 px
Posted on: 2025/10/29 8:21
Re: NOS muffler
And here is another NOS (deadstock) muffler, this time an aftermarket (equivalent) part, a Toyo Gold muffler N-150. It was on Yahoo earlier this year and didn't sell at 32,000 Yen
The last one I bought was a well-used factory muffler, but it was still quieter than modern replacements ... and it fit perfect
jpg  GOLD MUFFLER bend.jpg (154.15 KB)
174_690250ae91b0b.jpg 1120X464 px
jpg  GOLD MUFFLER b.jpg (152.02 KB)
174_690250bd74e06.jpg 1008X640 px
jpg  tail pipe with hanger tab.jpg (78.82 KB)
174_690250c4c3c01.jpg 600X400 px
jpg  GOLD MUFFLER bottom.jpg (100.12 KB)
174_690250d874a64.jpg 1136X320 px
jpg  GOLD MUFFLER outlet.jpg (164.98 KB)
174_690251a1e430e.jpg 1200X675 px
jpg  N-150 Toyo ゴルード マフラー.jpg (166.11 KB)
174_690251b543193.jpg 1024X675 px
Posted on: 2025/10/29 17:43
Muffler Stopper
Here's a factory piece I never noticed before. It prevents the muffler from banging against the floor
20635-18000 STOPPER-muffler
* B10 (all except earliest)
* B110
Early B210 to 1975 and all VB210 use the similar 610 bumper 20635-K0101
NZ Datsun Parts has this rubber bumper part for sale
jpg  20635-18000.jpg (32.04 KB)
174_69025583b1da5.jpg 600X400 px
Posted on: 2025/10/29 17:57
Edited by ddgonzal on 2025/10/29 18:49:54
Connecting muffler to exhaust pipe
When it's time to fit the muffler to the exhaust pipe
The muffler input slips over the exhaust pipe coming from the manifold
This clamp tightens it down with an M8 bolt
20620-H1000 CLIP-tube, exhaust
replaced by
20643-B5000 CLAMP-exhaust tube (from 1973-11)
Because I didn't have the factory clip, I used a 1.5" muffler u-bolt
To make sure the exhaust seals, use the factory Datsun muffler seal in the exhaust pipe groove
20720-N2226 EXHAUST TUBE SEALANT
or a tube of generic muffler sealant:
jpg  10160 VersaChem Exhaust Seal.jpg (95.35 KB)
174_690290aa1cd2b.jpg 560X1184 px
jpg  C-260_208-2 Exhaust Tube.jpg (53.67 KB)
174_690296d3a4b76.jpg 959X804 px
Posted on: 2025/10/29 22:10
Edited by ddgonzal on 2025/10/29 22:36:03
Edited by ddgonzal on 2025/10/29 22:36:47
New 1200 wagon muffler
VB110 muffler sold on Yahoo for 84 AUD
It's a Matuko muffler. Matuko went out of business in 2017. Perhaps the last vendor of 1200-specific mufflers?
wagon/van has a kink near the rear hanger. Is that to clear the fuel tank filler hose?
jpg  Sunny Van VB110 muffler.jpg (186.11 KB)
174_6903d425518c7.jpg 900X1200 px
jpg  van-wagon tailpipe view from bottom.jpg (46.89 KB)
174_6903d43a87022.jpg 960X256 px
jpg  outlet view from bottom.jpg (197.91 KB)
174_6903d452c479f.jpg 900X1200 px
jpg  VB110.jpg (150.66 KB)
174_6903d45c8a189.jpg 954X1200 px
jpg  wagon hanger kink view from top.jpg (137.52 KB)
174_6903d574e2213.jpg 592X1152 px
jpg  wagon bend.jpg (184.35 KB)
174_6903d5cf9ed14.jpg 800X1200 px
jpg  muffler top.jpg (197.23 KB)
174_6903d5ecb50fd.jpg 900X1200 px
jpg  muffler bottom.jpg (167.11 KB)
174_6903d617ccab7.jpg 900X1200 px
jpg  inlet.jpg (138.85 KB)
174_6903d626b1e33.jpg 1200X900 px
jpg  Matuko MB-067 VB110 Nissan 20100-H1400.jpg (127.71 KB)
174_6903d63281c68.jpg 900X1200 px
Posted on: 2025/10/30 21:19
