Rotary Conversion????
Quite a regular
From Wodonga Vic
Hello all
Just wondering if any ones has done a rotary conversion in a 1200 ute? Im looking at a 12A. Any ideas would be sensational thanks
Posted on: 2004/7/31 8:13
Re: Rotary Conversion????
nah just buy a lawnmower from ur local hardware.. same noise and they can help with uyr lawns! nah rotors are ok but they belong in dazdas
Posted on: 2004/7/31 8:32
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
turbo or non turbo... in nsw would be harder for turbo.
hardest part would be the crossmember in the front for mounting and also a stronger diff.
depends on budget but around $5000 to do a good job mechanically and legaly
Posted on: 2004/7/31 9:07
Quite a regular
From Wodonga Vic
Thanks for the info . You got any contacts down Melbourne way?
Posted on: 2004/7/31 10:41
From Melbourne,Australia
Speak to rotorworx in melb about your conversion they have done a ute with a 13b turbo
Posted on: 2004/8/1 8:30
ive researched this topic heavily bcas it has always and always will be on my to do list. the 13B fits in perfectly with very little work to do and give alot more power
keep us posted on how it goes bcas rotary rock and 1200 ute are the perfect body for them
Posted on: 2004/8/1 13:18
From Sydney
i have been to see Jim at Roccos performance about the same conversion and was told that it cannot be engineered in NSW even in NA form!
but then i supose it also depends on wether you know an engineer or not who will pass it for you... anything can be done, but getting it legal is another issue.
ring some engineers and ask before you do anything!
if you find someone to pass it let me know!
Posted on: 2004/8/1 23:11
From Toowoomba QLD
I have seen a rotary in an 85 ute here in QLD, it was set up for track so I don't know if its registered or engineered but I can find out.
Posted on: 2004/8/1 23:29
Quite a regular
From Wodonga Vic
No worries, however I was only looking at putting a 12A in, i dont mind having power but I guess you can have to much. Ill keep you informed on how I go.
I'll give Motoworx a ring, thanks for th info.
I know I can get it engineered in ACT and Vic. I live in Vic, so I'll give it a go.
Cheers for all your info
Posted on: 2004/8/2 7:40
From Sydney
my mate had an orange 1200 sedan with black speed stripes with an aspo 12a in it. he was told he couldnt get it engineered in nsw becasue they classify rotors outputs as double the actual output. for eg. 12a being a 2.4L and 13b being a 2.6L. dont know how true that is but if it is true it goes back to the old weight x 3 for aspo output and its a no no in that aspect.
Posted on: 2004/8/2 13:18
Street Tail Dancers
1200 coupe - A14
