Arches
Quite a regular
From South Africa
Hi Guys is there any way of rolling out or flaring the arches on my ute as the tires keep on touching at the top? Any help would be great
Thanks
Posted on: 2004/8/7 5:51
Old Datsuns never die they just go faster
Re: Arches
From Christchurch NZ
A no $$$ trick, is to get a peice of pipe and lever against the tyre whilstv rolling the pipe front to back. Done carefully you can make quite a nice wee flare effect which should solve minor rubbing problems. Be extreemely carefull about the peice of pipe above the part you are rolling. I used a peice of pipe that was too short once, and put it some very nasty stretched puckers which are near impossible to get out. With carefull perseverence you can pump it quite a way, but if you go too far you will start to lose the line down side of the guard.
Posted on: 2004/8/7 7:23
Forced Induction!
