A15 modifications
i need help making my A15 fit my 1200.does any one have any
ideas?
Posted on: 2002/1/10 5:26
Re: A15 modifications
From Sydney, Australia
what is wrong? is it that the engine mounts do not line up? If so, u need to get the left one from the a12, and get the right one(dizzy side) from
an a14/15 vehicle.
what else doesnt fit?
the crossmember perhaps? get one from a 1200 ute.it will fit.
Be more specific about your problems, and we can help. It is the easiest engine swap there is, apart from putting in another a12.
Good luck
Linc.
ps which country u from?
Posted on: 2002/1/11 3:11
do i use the same 1200 rubber mounts? or do i need to get some different
ones.
long beach, cali. united states...
Posted on: 2002/1/11 10:29
Not too shy to talk
We put A14 (same motor mount positions as A15) in our 1200 race cars. We make brackets that mount to the A14 engine to allow use of the A12 motormounts and mount brackets and
still keep the 1200 crossmember. Call me at the shop and I'll measure the plates we use to move the motormount brackets. Peter 314 291-8441 or cell 314 724-7098 or
peterzekert@juno.com
Posted on: 2002/1/11 10:44
yeah same rubber mounts...
Linc
Posted on: 2002/1/12 1:42
From Snohomish, WA USA
All you need to do is get yourself a 1.5 by 4 inch piece of metal 3/16" thick and weld it to the A15 motor mounts in the position where they come in contact with the rubber
mounts on the cross member. Weld them with the excess material extended forward. Drop the motor in and mark the new holes for drilling. That has to be the easist way to do it.
Mine works fine.
Ernie
Posted on: 2002/1/12 1:45
Quite a regular
1200 ute ones fit in Aus, but may not in other countries - remember the different versions of
A-12's arguement.
Posted on: 2002/1/12 9:28
