a14 5spd gearbox
hi i am in hawks bay nz and i hav a 1200 with a a14 turbo and i need some one to build me a strong 5spd gearbox as std ones just don't last ne help would be good
Posted on: 2004/8/12 0:27
Re: a14 5spd gearbox
From Invercargill, New Zealand
Your best option is the alloy case Celica box. You won't break it and you can make up your own conversion bellhousing if you have to. Otherwise grab a Dellow conversion kit for the A series. Cost will be about the same as someone building you a Datto box with strengthened internals and then there is still no guarantee it will hold together. What are the specs of your A14?
Posted on: 2004/8/12 0:44
its a std a14 block with efi turbo on the side it run a 14.4 and i blue the head 3quarter the way down the track i hav dun sum more work on it and i thick it will a 13.5 next time
Posted on: 2004/8/12 6:08
From Perth W.A
What is the EFI from?
and what turbo are you using?
Posted on: 2004/8/12 6:14
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
i am tring to put a pxt on but it wont work
Posted on: 2004/8/12 6:56
From Perth W.A
they need to be a bit smaller probably, the size of the image file is too big. you can e-mail them to me if you like and i can make them smaller. just don't zip them up.
Posted on: 2004/8/12 7:06
120y Coupe
Also try Reg Cook, hes in Auckland some where. He builds straight cut 4/5 speeds
Posted on: 2004/8/12 7:31
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
From Taupo New Zealand
yeah a reg cook gearbox would be very nice but for the same money you could probably get the toyota t50, convert it, recondition it, get a close ratio gearkit from palmside, shout all your mates on the piss for a weekend and put a deposit on a house. but I'd still love one!
Posted on: 2004/8/12 8:13
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
There is a Datsun box that fits and does the job nicley- its from a 1400 Sunny GX Coupe, has the dogleg shift pattern and a hydraulic clutch. They are substantially larger internally than even the 1400 box, the gear size being closer to the 180B box and are ideally suited for your requirements. Behind the turbo A14 with a 3.9 diff the ratios work very well. Good luck finding one but they are around so keep at it until you find one.
Look forward to seeing some pics of your car.
Cheers
Dave
Posted on: 2004/8/12 8:33
i got my pxts on ther nz 1200
Posted on: 2004/8/12 10:06
