Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
head gasket????
TUFDAT
Posted on: 2004/8/17 9:35
i was looking on ebay and i found a set of gaskets starting bid $19.99 and the guy doesnt know what what there for if anyone can tell me what there for as i am desparetly in need of new gaskets any help will be greatly apreaciated Cheers Rick
#2
Re: head gasket????
dattodude
Posted on: 2004/8/17 11:11
If the gaskets are for an A-Series, please talk to NISPARES in Melbourne.
They also only cost about AU$20 and it's for a gasket set. After postage.. Ebay is not always the best method. They get my "2 thumbs up rating". I bought my rear door skins from them. Cheers Nispares Website
#3
Re: head gasket????
TUFDAT
Posted on: 2004/8/17 11:49
thanx alot chris i will ring them tommorow cheers
#4
Re: head gasket????
NoPsi
Posted on: 2004/8/17 12:10
Just had another look at the phto man. On second thought I reckon it is A12. I thought the rocker gasket was the sump one. Pretty confident it is a12 though. However sounds like the price is too high.
Craig
#5
Re: head gasket????
_steve_
Posted on: 2004/8/17 13:54
i no the a12 and a14 head gasket is the same i dont no about the a15
#6
Re: head gasket????
Dodgeman
Posted on: 2004/8/17 14:28
The A10 & the A12 from Datsun 1200's are the same as each other, as these had the additional hole for the rocker oiling. When the revised A12 was introduced in 1974[?] it used a diferent method of rocker oiling, & this additional hole may not be present in gaskets listed as being for the 120Y & A12 Sunny's. A14/15 engines used a diferent gasket as these engines went to the larger 76mm bore size. You could use the A14/15 gasket on a late A12, but i would be a bit shy about using a late A12 gasket [small bore] on the A14/15 block. The early A10 & 1200 gasket should be OK on a late A12 as the extra hole in the gasket does not interfere with anything. The last head gasket that i used in my GX was an A14/15 type, & i used a wad punch to make the extra hole that was necessary for the early engine's rocker oiling. I needed to use this gasket as i had a 76.5mm bore size. Feral is making some top notch head gaskets just for crazies like me. Gaskets aint gaskets, Saul You can view topic.
