moving master cylinder to clear carbs?
From USA
I am installing twin side drafts on my 1608 engine in my LHD B210. The master cylinder will not clear the carbs and air cleaner. I did a search and can't find anything about it. Can someone give me an idea of what master clyinder they used, or how they did this?
Thanks
Posted on: 2004/9/4 4:32
Re: moving master cylinder to clear carbs?
From Coondle, WA Australia
If you have some money to spare, you could make a custom air cleaner setup simiilar to the gx setups, with the intake pointing to the front, kinda like the ole frypan setups. I dont think they do anything for performance though. Something like what is in the pics for the twin webber turbo setups
here
Posted on: 2004/9/4 8:59
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Perth
Since you insist on sitting on the wrong side of the car this is alittle bit of a problem for you
Have you considered relocating the master cylinder under the dash ?
bobs cyl
bobs cyl
Posted on: 2004/9/4 10:12
