« 1 (2) 3 »
Re: misfiring? plz help
From Stone Age somewhere in U.S.A.
more to the point cyls 1 and 4 are directly across from each other on the cap:
1 2
3 4
swap any two across and it will still run, just not too well
remember the firing order is 1-3-4-2
not 1-2-4-3
Posted on: 2004/9/8 6:14
From sutho shire, NSW, AUS
I put a set of new spark plugs on and they fouled up real quick and were running #### within hours or driving. It really lost power and when we pulled the plugs out they were terribly fouled black.
to me this means that the performace is deteriorating, and swapped leads is not the problem
Posted on: 2004/9/8 6:29
I see your point. He put new plugs in, and it ran good for some time, but gradually got worse.
Posted on: 2004/9/8 6:35
From Sydney
i didnt swap those around im not an idiot i cable tied them well enough in a position i wouldnt get them confused. The car ran PERFECTLY this morning after we changed the spark plugs with the old ones again. But for some reason its ####ing up again.
I think the deposits on the distributor cap may have given me a false reading when i was tuning the carby??? I will check to see if they are all fouled up this time.
Thanks for the help guys keep posting though i need more ideas!
It wasnt running poorly it was most certainly running on two pistons yesterday.
Posted on: 2004/9/8 6:38
Don't take it personally ... I've misrouted the spark plug wires many times myself. It has nothing to do with calling someone an idiot.
Posted on: 2004/9/8 6:41
From Toowoomba QLD
Am I to assume that the car runs perfect with the old plugs and plays up with the new ones??
Wouldn't be the first time a new plug was faulty.
swap these two plugs to a different cylinder to check if the miss goes with them or stays with 2 & 4
Posted on: 2004/9/8 6:46
true dat datto7,
just put your old sparkies back in and see if that fixes it.
Posted on: 2004/9/8 6:52
From South Africa
Besides, the plugs being black,,,,,,any traces of water/moisture on them?
Posted on: 2004/9/8 7:33
Life's a bitch, so f...k it.
nor am I trying to imply that your not inteligent, it's just that we can all make a mistake now and again, or get sidetracked or distractracted.
IF all else fails, go back to the basics, is the point gap correct? are the valves properly adjusted? is the timing at the correct setting? ETC.
I have, over the years seen where valves are ourt of adjustment, and they will be tight, as in keeping some or all of the valves partially open. intake valves are prone to do this on A series engines and the exhaust valves will be loose.
all any of us are trying to do is offer suggestions that might help, please don't take it personal.
Posted on: 2004/9/8 7:43
From South Africa
Good advice, and well said, RGRINDER
Posted on: 2004/9/8 7:57
« 1 (2) 3 »
