15m head A series / g16de on e series?!
Hey 1200RC can you get the pics up on this head or can you get me the contact no of this person to see if he`ll sell a kit for us?
Also anyone know the ga16e engine?
I see that they are the same bore and stroke as the e16s and wondering if the gearbox bolt on patterns are the same cause they ran on the same car the same years with just what appears to be either the e16i or ga16e? If so it would mean that the twin cam ga16e engine would fit as well as the e15s would or a ga16e head could be adapted onto an 82 model e15s engine without the catalic converter and minimal pollution gear.
Feral any part numbers you can dig up??
http://www.autobook.co.kr/data_links/nissan_small_engine_spec.htm
http://www.geocities.com/pulsar_exa_89/engine.html
even same compression ratio and spark plug gaps!!!
Posted on: 2004/9/8 13:17
Re: 15m head A series / ga16e on e series
Isn't the GA16 a front wheel drive engine??
Posted on: 2004/9/8 14:30
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
Re: 15m head A series / g16de on e series
Yes and so is the e15s but they bolt up to the rwd box except for one bolt.
Check this thread
http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=12178&forum=1#48100
I was trying to post there but again started new thread
Posted on: 2004/9/8 14:35
I know that the GA uses a 9 tooth starter and the A series uses a 8 tooth and thats about all I know I hope this is helpful
Posted on: 2004/9/8 14:42
Well I just looked at all the pictures in the website in SAfrica and it looks like the gearbox for the E16S will also fit the ca18de and lates sr20de series engine (? as number there on the site) I think the micra engine is different there but I still cant believe that the gearbox housing pattern are maybe the same!!!
I wonder now if the e15s has the same bellhousing as the sr20de!!??? anyone???
http://www.nissan.co.za/buying_parts.asp?s=4#
try this thread then click on "passenger vehicles" above in the grey panel then window pops up then follow through and select the sentra, then powertrain then transmission case and... youll see the diagrams they are phenomenal!!!
Posted on: 2004/9/8 14:48
