« 1 (2)
Re: sloppy gearstick?
From Coondle, WA Australia
if you cant justify the cost, I have used a bit of garden hose before. not ideal, but it works.
Posted on: 2004/9/9 15:03
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Toowoomba QLD
Thankyou Abyss, I can stop searching the rubbish bin for the packet and invoice now.
Posted on: 2004/9/9 22:55
From South Africa
Mine was f...ked, big time.
I bought the plastic bushes, but then realised that the g\stick pin at the bottom wasn't there except a bolt and nut jobby instead.
This pin had to be placed on order, and I had to wait a week before collecting it.
So what did I do?
Well, the bushes wouldnt work with the bolt and nut set up, so I cut a pice of rubber hose, fitted it in the stick at bottom, shoved it in and put the bolt & nutthrough,
Whallllah,no sloppiness
Posted on: 2004/9/11 7:16
Life's a bitch, so f...k it.
« 1 (2)
