Fuel Regulator?
From Wanganui, New Zealand
I have almost finished putting my a15 back together for my ute and I have installed an electric fuel pump. It says on the box that to is operating pressure is from 3-4psi. Would this to much for dhla dellortos? Do I need a regulator for high rpm? and would there be a difference in hp with one?
thanks
Posted on: 2004/9/12 7:55
Re: Fuel Regulator?
From Newscastle, Australia
I have the same setup in mine with webers...I havent seen the need for a fuel regulator at this stage but its highly recommended. Have you installed one of the NZ made fuel-flo ones...Ifso and you are using for street you should be OK. If you are racing it it may be wise to fit a fuel reg, they are only $52 AUS....
Posted on: 2004/9/12 9:16
Dont die wondering.....
Re: Fuel Regulator?
From Little Rock, AR
I set mine at 3.5 psi and it ran best....yours could be different based on tuning/jets but I ran mine a little high to overcome a lean condition rather than try to hunt down new Dellorto jets
Posted on: 2004/9/12 9:19
Re: Fuel Regulator?
From Melbourne, Australia
you only need a reg if the pump is making over 5psi, as over 5psi will overcome needle and seat i believe
Posted on: 2004/9/12 11:26
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
