Fuel System Problems
Quite a regular
From Blue Mountains, NSW
i got a '80 1200 ute. it fires up fine but when given a few revs for a while (about 2mins) it runs out of fuel. i checked out that little glass window under the carby and the fuels there to start with but when revved it gets burnt up and no new fuel enters. I suspect its the fuel pump but im uncertain. I checked out the tech section but to no avail. Can somebody help me!
Posted on: 2004/9/28 6:06
So Many Pedestrians, So little time!
Re: Fuel System Problems
From Sydney Australia
Check the fuel filter isnt blocked first.
Then if it isnt disconect fuel line from carby aim it away from yourself and the car crank the ignition for a bit if fuel shoots out then the fuel pump works.
Chech these 2 things and tell what happens.
Posted on: 2004/9/28 6:14
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
From Sydney, Australia
Yep, it's the pump, the filter or a very sticky needle and seat in the carburettor.
Chris
Posted on: 2004/9/28 6:19
Before you start buying replacement parts, perform the fuel pump test.
If you don't have a pressure gauge, you can still perform the volume test, you only need a coffee can or something to catch and measure the fuel against.Quote:
Fuel pump test
Low fuel pressure often has this symptom: Engine idles fine, but when you "give it the foot" it runs poorly, backfires or runs slows down. High fuel pressure can cause poor fuel economy or flooding (raw fuel running down throttles).
1. Pressure test: Use a tee line to tap your pressure gauge into the fuel line near the carb. Pressure with engine running should be 2.4 psi or slightly more
- If the pressure is significantly higher with the stock A12 fuel pump, replace the pump
- If the pressure is low, replace the pump
2. Volume test: disconnect line from carb, put in quart/liter container. Start engine and run at 1,000 rpm for one minute (use a stopwatch). 450 cc or more should be pumped
Caution: don't let the gas spill!
If this pumps less than 450 ccs, try without the fuel filter:
- If it improves, replace the fuel filter
- If it doesn't the pump is likely bad. It could also be a clogged line, but this isn't too common unless the car has been sitting for years without running
reference
Posted on: 2004/9/28 6:27
Not too shy to talk
From Adelaide
i have just recently had the problem where i ran completley out of fuel which brought all the crap out of the bottom of my tank and slighty blocked my jets i had to strip the carby and clean it i also drained and cleaned my tank
Posted on: 2004/9/28 10:30
