Browsing this Thread:
1 Anonymous Users
Re: Rumbling Noise |
From Christchurch, New Zealand
I have the same setup as you with a 32/36 Weber and a Ramflo filter. The induction noise of this setup is amazing and easily overbears the exhaust and the old carby. That is what the rumbling noise will be. You should also be able to clearly hear it sucking when you accelerate.
Posted on: 2004/10/6 11:15
1972 Datsun 1200 Coupe Rosso Corsa Red 14" Watanabes Twin 1.5" SUs to go on Extractors w/ 2" exhaust and muffler Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
From Brisbane
I dont think its normal cos this is the 2nd time I installed a weber and its not normal its like air turbulence kinda noise not the suction noise yeah you can hear the suction noise when you rev it. I can hear the noise louder in the egnine bay area probably coming from the cabry? Yesterday I was driving and stop at the traffic light and when i tried moving the carby backfired not really loud though.
Posted on: 2004/10/6 21:57
could be a acumleak in there some where or its running lean, did you rebuild the carby or just whack it on datsun style. Also did you retune the car and the carby. What other mods are there, if its just the carby, yu could be running way to rich as well. need more info from this side of things now.
Posted on: 2004/10/6 23:18
From Brisbane
tried setting the carb leaner but then it then runs rough and dies on road on brake or taking off so I adjusted it to run rich but the "rumbling" noise is louder and the car blows black smoke cos its running rich. so I adjust the mixture again and now runs great no smoke only problem is that noise on decelleration on gear.
I rebuilt the carb myself checked everything and change all the worn out stuff.
Posted on: 2004/10/7 0:11
Registered Users Contentmaster Usermaster
If the air/fuel mixture is overly rich, it can cause a bru-bre-brap-bru sound when you let off the throttle. To resolve that, simply adjusting the idle mixture screw is not enough. You need to tune the jet and more importantly the air bleeds to get it just right.
So why not just put the Hitachi back on? It didn't rumble ...
Posted on: 2004/10/7 2:56
From Brisbane
the hitachi did not rumble but it didnt have the grunt like the weber
Might take it to carb specialist to tune it
cheers!
Posted on: 2004/10/7 2:59
What size jets are you running?
Posted on: 2004/10/7 4:58
From Brisbane
I did not change the jets thought wont encounter a problem...
the guy where I got the carb was using it on his 1600
not sure what size jets
Which jet is responsible for this issue?
Posted on: 2004/10/8 1:32
