Fuel Line
From Palmie, New Zealand
Is 6mm appropriate for fuel hosing?
Posted on: 2004/10/10 7:21
Re: Fuel Line
From Sydney
i think it is for an a mechanically driven fuel pump, however 8mm is better for an electronic fuel pump depending on the pressure needed, although i could be wrong so dont take my word for it. while on the subject are 1200 coupes 6mm or 8mm standard?
Posted on: 2004/10/10 8:35
Street Tail Dancers
1200 coupe - A14
Re: Fuel Line
The stock Datsun 1200 fuel lines are 1/4-inch (6.3 mm). It doesn't matter whether you are using mechanical or electric fuel pump. The Datsun carb (or the Weber 32/36) uses low pressure, low volume so 1/4 line is appropriate.
Most V8s use 5/16 inch fuel lines (8 mm).
Last week I worked on a 1978 truck with 7.5 liter engine (Chevrolet big-block 454) and it used stock 3/8 fuel line.
Posted on: 2004/10/10 16:53
Re: Fuel Line
So would 6mm be appropriate for an A15? or a worked A15 with just a weber carb? cheers
Posted on: 2004/10/11 8:16
Re: Fuel Line
From Sydney
yeah sorry thats wat i meant but it all came out wrong. yes 6mm would be fine for an a15 because fuel pressure etc isnt increased substantially
Posted on: 2004/10/11 8:33
Street Tail Dancers
1200 coupe - A14
Re: Fuel Line
From Newscastle, Australia
Ive got 3/8 fuelline in my coupe (worked A15 with twin carbs) with twin electric 4 psi fuel-flo branded fuel pumps and it runs really well.
Posted on: 2004/10/11 9:22
Dont die wondering.....
Re: Fuel Line
The standard 1/4 inch fuel line is good for at least 100 hp. 5/16 would be good for 250 hp or so ... Quote:
Up to 250HP = 5/16" or -04 AN
Up to 375HP = 3/8" or -06 AN
http://www.centuryperformance.com/fuel.asp
Posted on: 2004/10/11 16:26
