45mm Side draught webber work good whith a turbo setup
From Melbourne, Australia
i have some and i want to no if i can use them on a turbo
Posted on: 2004/10/8 11:57
When the going gets tough the Datsun keeps going😋
Re: 45mm Side draught webber work good whith a turbo setup
Yes, you can use the Webber on a turbo setup & it can be tuned to run very nicely.
I had a friend & workmate with a show van back in the 70's [Holden HQ Midsummer Dream] that ran a Webber as a suck through on a turbo. He had removed the butterfly on one side & fitted a welch plug to make it a single barrel carb. It went quite well too.
With a turbo, the airflow is constant, instead of pulsing, as in multiple carb setups, & it actually flows a lot more air this way than you might think.
Posted on: 2004/10/8 13:58
Love your Datsun.
Treat it well.
are you talking single or twins???
either way it's possible
a dude here has twins in his 100A with a turbo setup, some very good pics and a very helpfull guy aswell
im struggling to remember his nickname now
but look up 100A and turbo and you should find some info
Posted on: 2004/10/8 16:14
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
single
Posted on: 2004/10/17 14:02
From Canberra
what would a single 45mm sidedraught weber be worth?, I'm looking for one to put on my L20B
Posted on: 2004/10/18 2:42
i have a single L series manifold.
Posted on: 2004/10/18 6:28
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
From Canberra
I have a single weber L-series manifold too, but there's nothing on the end of it
Posted on: 2004/10/18 8:57
from $100 2 $300 $$$$$
Posted on: 2004/10/18 12:18
