center support bearing
should i keep the driveshaft setup on my truck.it has two drivshafts with the center support bearing.will it break during racing.i was thinking of making the driveshaft direct.is it possible to break anything with the stock setup??which way is better??thanks for putting up with me
Posted on: 2004/10/30 4:07
Re: center support bearing
From Auburn, Washington
It will depend on if you have a slipyoke in the tailshaft of your transmission and the length of your proposed one piece driveline. The driveline shops here won't balance a driveline longer than 5 feet.
Posted on: 2004/10/30 4:44
how about the stock setup??will it break.
because i would like to keep the stock setup. but if it will fail on me the solustion it direct shaft.
and the driveshaft would never be longer than 5 feet....from tranny to rearend.
Posted on: 2004/10/30 5:21
Yes, it might break.
No, it might not break.
You're going to have to run it to find out. There are too many factors for anyone to say. Maintenamnce and driving style are two of the biggest issues.
Posted on: 2004/10/30 13:17
do you know or heard of any one who did break it in racing/drag racing.beacause i think lots of cars have that type of setup.it comes stock in toyota's.......and lots of others.if they deside to race there car do they make any changes.??
Posted on: 2004/11/1 20:27
Datsun 1200s have one-piece driveshafts. It's mostly trucks that have two-piece. So you might ask in a truck forum or a drag racing site.
Posted on: 2004/11/2 4:53
From Sydney, Australia
Most longer wheelbased cars have the 2 piece tailshaft. Including many 1600kg+ V8 sedans, and trucks.
By changing to a single piece shaft, you will weaken the unit (or make it heavier).
Adapt a bigger centre bearing if you break your existing one.
Start worrying about the important things..like can you afford the project.
Posted on: 2004/11/2 5:00
Why do i have to worry????????
the center support bearing is only around $80.00.
WHY WORRY??? why
Posted on: 2004/11/2 5:38
right know i have no bearing on.
how do i put the new one in??????/
can someone take me step by step.thanks
Posted on: 2004/11/3 6:27
We are using "general" information to help you out with your 620. None of us know much about the 620. It's time you got a little more self-sufficient and started reading some books on the 620.
for US$3.99 you can fix things yourself. Please invest in a Workshop Manual
Before you start insulting me, I have plenty of Datsun 1200 books, that's why I know a fair bit about them.
I doubt anyone on here can explain to you how to change/install the center bearing for the tailshaft on your 620, and I can tell you that I certainly don't want to learn about them.
Chris
Posted on: 2004/11/3 6:48
