Browsing this Thread:
1 Anonymous Users
oval ports n overheating |
From Palmie, New Zealand
soo, i've ran a search and i've read the tech section head info, so all A15 heads are oval port? no a12 heads are oval port besides the gx? or are later a12's (a12a) oval also?
what would be the main most common problems for overheating, took the dat for about an hours cane and it was quite hot weather but when i had finished temp was about 6/8 along on the temp gauge, it hasnt overheated on drives of this length before, usually stays on half. so any suggestions?
Posted on: 2004/11/7 8:07
Re: oval ports n overheating |
From Sydney, Australia
The only oval port on the A-series is the GX head. Not A12A. A14 GX are oval too. I don't know accurately which are oval, but I'm certain it's got nothing to do with your overheating.
1. Rubbish and buildup in the radiator. 70% 2. Waterpump 15% 3. Stuck thermostat 7% 3. Loose fan/Water pump belt 5% 4. corroded/choked water galleries 2% 5. stuffed temperature sender 1%
Hope this helps.
Posted on: 2004/11/7 8:24
Registered Users Contentmaster Usermaster
All the A15s I've seen are oval ports, as are most A14s. But Nissan had way too many running changes to say for sure about anything they did ... Per dattodude's reply they seem to be different in Australia.
The newer A12s have round-port heads, as did some A14s.
The oval port engines don't overheat any more or less than round port engines.
Posted on: 2004/11/8 3:21
haha, no the oval port and overheating were two seperate questions, just didnt want to clog up the place with 2 posts. anyway so id figure an oval port head thats said to be an a15 will be an a15.
overheating, main cause is radiator in general. so i should take her to a radiator specialist and get them to check it out? i do think it has a pin hole leak which wont exactly be helping things yeh?
cheers
Posted on: 2004/11/8 4:55
From Taupo New Zealand
get it fixed, it's not expensive. I got my 1600 one done with a triple row core for $230. Cheap as chips. (cheps for you aussies  )
Posted on: 2004/11/9 5:36
1970 1200 coupe A15 1972 1600 original except for nana's sheepskins 1978 B310 SR16VE
From sydney
Maybe there is nothing wrong,If you were caneing it for an hour on a hot day it is to be expected that it would heat up a bit more than normal.
Posted on: 2004/11/9 5:56
If you even suspect that the radiator is becoming a problem, then pop it out & have it properly cleaned & tested. While it is out, go & buy a new thermostat, or at least, test your old one & make sure it is working oroperly. I had a new triple row core supplied for the radiator in my 200B [810] & was surprised at just how little it cost over & above the price of a stock replacement core.
Look at it this way, if you spend say, $100 on a rediadtor clean out & service, along with a thermostat, it will compare quite favourably against the possible cost of a lost engine, the inconvenience of being stranded, & the cost of the tow home. Factor in the fact that if this disaster should befall you, then you gotta do the radiator thing anyway. An ounce of prevention,...etc.
Posted on: 2004/11/9 6:22
Love your Datsun. Treat it well.
