1976 B210 coupe 2 door not HB Interchange question
From PHILLY USA
I just picked up a 1976 Datsun B210, I bought it from the original owner. Awesome little car. Carb is acting up. I found a Datsun 510 wagon fully intact in a local salvage yard and was wondering if the Distributer and carb will work on the B210? The 510 is AT and my B210 is MT 4 speed. If not does anyone need some 51o parts?? LOL.
Posted on: 2004/11/13 5:11
Re: 1976 B210 coupe 2 door not HB Interchange question
Very little from a 510 fits a B210. The engines and transmissions are totally different. The distributor won't fit. The carb won't fit.
For B210 2-doors, if it's not a hatchback then it's a called a "2-dr sedan", definitely not a coupe. The only coupe was the hatchback.
Posted on: 2004/11/13 7:37
Wheels will fit the pattern.Other than that, unless you have an engine swap in mind, (taking engine + crossmember off the 510), there is little you can do.
Posted on: 2004/11/13 8:24
