« 1 (2)
Re: Update to my 1200GX running hot on the highway problem.Please give comments
From South Africa
Hi, Guys,
Slightly off topic, but,
what will happen if the thermostat is taken of, which I have done.
Well, the guage does fluctuate at speeds, never going over the middle mark even at speeds of 140-160 kms on the open road.
My question is, Will this have an adverse effect on an engines lifespan?
Posted on: 2004/11/20 5:30
Life's a bitch, so f...k it.
From Newscastle, Australia
Yes it will,leaving a thermometer out of a car will increase the amount of time the engine takes to warm up thereby increasing wear. The reason for the increased wear is that the oil wont lose some of its viscosity and wont flow into some of the vital components. Also the thermometer regulates the heat so the engine isnt constantly expanding and contracting which puts a strain on gaskets and welch plugs and the like. I remeber Alan Moffat talking about when he came into the pits at Bathurst, the engine was allowed to cool slightly and then when he went back out the engine blew up due to thermal shock.
Posted on: 2004/11/20 5:53
Dont die wondering.....
From South Africa
Thanks for that helpful info CONVERTED, well now, its off to the spare shope I go, to buy a new one.
I didnt think that much of the t/stat being removed.
WE LEARN EVERYDAY
Posted on: 2004/11/20 6:04
From Melbourne, VIC
Just to throw my two cents worth into this discussion, the last time I had a radiator flushed out the guy said never to spray water into the front of the radiator, through the grille, to clean dirt out as this only turns it into mud and cakes it on. Only clean it by using a blast of compressed air. Don't know if this could be a contributing factor, but it may be worth a look.
Posted on: 2004/11/20 8:19
« 1 (2)
