dellow 5spd conversion question
From Melbourne, Australia
what clutch activation does this use?
just stock 1200 cable???
Posted on: 2004/11/26 2:08
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: dellow 5spd conversion question
From Sydney
1200 clutch cable.....also uses the 1200 thrust bearing fork/lever.......
Posted on: 2004/11/26 3:34
From campbelltown (sydney) australia
what about things like gear stick, where it comes through? and mounting the box do u need to make custom mounts? and tailshaft, do they make the kit so u can still use the 1200 tailshaft?
Posted on: 2004/11/26 3:54
From Sydney
stick comes out slightly further back, so you need to elongate the hole in the tunnel. Custom mounts will need to be made.....shorter drive shaft will also be required.
Posted on: 2004/11/26 4:04
