Do 1200 ute leaf springs make a 1200 coupe sit lower?
Quite a regular
From New Zealand Invercargill
as above, i was told tht they do, just need to knw for sure
thanks
Posted on: 2004/12/2 9:25
Re: Do 1200 ute leaf springs make a 1200 coupe sit lower?
From Sydney, Australia
Coupe and Sedan 55020-H1000
VAN 55020-H1401
VAN (Opt) 55020-H1400
UTE 55020-G1000
My answer would be...maybe.
Posted on: 2004/12/2 10:10
From Christchurch. NZ
Well I Have some if you would like to give them a try
Posted on: 2004/12/2 18:36
Did we ever get a definitive answer to this?
Coupe/sedan pack has 3-leaves, each leaf being thinner than Ute. The ute pack has more leaf camber (so the ute will sit higher).
Ute has two types of Leaf Springs:
4-leaf pack: 589 in/pound
5-leaf pack: 829 in/pound
The main leaf is 6mm thick for all sedan/coupe/van/ute.
Maybe using a Van leaf set with the bottom leaf removed would be the ticket?
Posted on: 2013/1/28 5:01
