manifolds & head porting
From Seattle ,WA.
does anyone know the following : Are all standard A12 heads round intake ports & GX heads oval ports ? Is this correct ? Were there any exceptions ?
Any info would be appreciated.
Thanks, Evan
Posted on: 2004/12/20 4:03
Re: manifolds & head porting
From Melbourne, Australia
all a12 are round port
all a12gx are oval port
all a15 are oval
a14's can be either round or oval but generally are oval
a14gx are all oval
only way there could be an exception is if there was after market porting done to make it so
all oval ports also use a diffrent inlet manifold stud pattern to all round ports (again unless studs have been added), round ports have a single stud between two inlet ports at the top, oval ports have one stud outside each port at the top
gx heads have double valve springs which you will be able to see if the rocker covers off
there is identification numbers, but again these are under the rocker cover
all exhaust ports and manifold studs are the same
then there is water jackets, and im not gonna try remember off my head which ones do and dont have those
Posted on: 2004/12/20 6:38
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Christchurch NZ
GX oval intake ports are taller than A14/14 ports.
Posted on: 2004/12/20 7:17
Forced Induction!
From Philadelphia, PA
Evan, on this site there is great info on this subject. Go to Tech Section/ Engine / A type cylinder heads. Photos of heads, specs, codes etc.
Posted on: 2004/12/22 17:29
From Christchurch. NZ
But here is the exception, says it's a 1200 head?
Posted on: 2004/12/22 18:30
