weber bolt patterns
From A.C.T, N.S.W
Does the DCOE and IDF weber have the same bolt pattern as a 32/36 carb? if so, with an adaptor (and all the mods needed for fitting a 32/36) could i use a IDF carb?
Posted on: 2005/1/3 2:53
Re: weber bolt patterns
From A.C.T, N.S.W
Urgent!! a friend is offering me a 40 IDF weber, used on his dads a 4cyl. torana, he's offering it to me for $200, and would need to know if i would need a new intake manifold for this carb?
Posted on: 2005/1/3 6:47
From Castro Valley,CA USA
the horizontal ones are DCOE's, the vertical ones are IDA's or IDF's.
It would take an interesting adapter and possibly a hole in the hood to get an IDF to fit.
I'll scan and post something regarding bolt patterns.
Posted on: 2005/1/3 8:27
Posted on: 2005/1/3 8:35
From A.C.T, N.S.W
looks like i will have to find a new intake manifold for it QUICKLY or i will have to let this oppurtunity slip up
Posted on: 2005/1/3 9:51
From durban, south africa
i've got a 44 idf that i want to bolt on to my 1400, but i've had a manifold made up, looks good and works well. what motor is that in the pic?
will post pics of it soon for you to get some ideas
cheers
Posted on: 2005/1/3 13:35
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
From A.C.T, N.S.W
is the manifold a modded stock one or a custom job? could you post some pics please
Posted on: 2005/1/3 21:12
modified stock on, works great lots of welding to do though, i'll try post pics by the weekend
Posted on: 2005/1/4 6:02
VW chassis
fibreglass body
A-14
280 cam
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
