Need help to adjust tappets
From Trinidad W.I.
Hi, does anyone know the valve clearance for the A15 engine, I would like to adjust mines they are making a little to much noise. Also I need help in knowing how to adjust them, is there a particular way to go about adjusting them or can I adjust them just like that after I remove the tappet cover?
Posted on: 2005/2/21 4:39
Re: Need help to adjust tappets
From Castro Valley,CA USA
If you turn the engine by hand untill the #1 piston is a top dead center, you should be able to adjust valves 1,2,3 and 5. With #4 piston at TDC you can adjust 4,6,7 and 8. Count the valves from front to back.
I don't have an A15, but that's how I've adjusted the valves on my A12 and Mazda B2000 engine.
I'm not sure how much clearance. It's around .010-.012 thousanths of an inch.
Posted on: 2005/2/21 9:33
From Mudgee NSW Australia
I used to set mine at 14 thou both inlet and exhaust thats with the engine warm.
Cheers
Posted on: 2005/2/21 9:35
If In doubt run more BOOST
From Trinidad W.I.
Thanks fellas I'll try it
Posted on: 2005/2/22 5:09
I did my valves using the method described eariler, then as a check, i did it properly to discover that the adjustments were now off. Ever since then i have done it one cylinder at a time & the engine should be hot, ie at full operating temp, not just warm.
Posted on: 2005/2/22 9:25
Love your Datsun.
Treat it well.
From sydney
my tappets are real loud wen the car is running hot is that normal??
Posted on: 2005/2/22 10:03
No.
Posted on: 2005/2/22 13:45
Love your Datsun.
Treat it well.
