Audio problem
From Christchurch, New Zealand
i put a amp and sub in my car today.....it works fine when im listening to the radio, but when i play a cd the amp/sub turns off.
the amp is a sony xplod 600watt, the headunit is a sony xplod mp3 headunit and lightning audio sub.
has anyone had a problem like this before?
Karl
Posted on: 2005/3/2 8:21
Re: Audio problem
From Ballarat, Victoria, Australia
if u've got the strock standard alternator in...it'l continue to do this....doesn't keep enough
charge or how ever u like to put it... i had to get a new one...ended up
getting an 85 which is quite sufficient but
quite expensive considering thei had to make up andother bracket to fit etc.
Posted on: 2005/3/2 8:54
-1200 4 Door Sedan, 2Pac Aruba Blue, Custom White Interior, OBX Racing Seats, SONY Head Unit, FUSION Speakers, 14" Bathurst Globes, Lowered, Powered By: A15 with Twin 40s,
Re: Audio problem
Or you could just bring it down to me and I'll fix it for you!!!!
Posted on: 2005/3/2 9:11
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
Re: Audio problem
yeah but if that were so muke, wouldnt it effect it all the time even when i listen to the radio?
might take u up on that offer blair as im heading down south either this weekend or the next. gotta catch up.
Posted on: 2005/3/2 10:17
Re: Audio problem
Sweet as, just pm me.
I think that I know what is wrong, but I'll wait, as I want to see the set up first.
Posted on: 2005/3/2 10:24
Re: Audio problem
cheers mate. its all setup correctly, tis earthed, 12v power wire and fuse is connected, remote wire is also connected to headunit.......so its pretty weird.
Posted on: 2005/3/2 10:28
Re: Audio problem
Yes it sounds like it, but we will see soon enough...............
Posted on: 2005/3/2 10:31
Re: Audio problem
indeed. u dnt use msn messenger do ya?
Posted on: 2005/3/2 10:32
Re: Audio problem
Nah, just pm's and text....... got no time for messenger type programs........they pi$$ me off
Posted on: 2005/3/2 10:36
Re: Audio problem
But its connected to the aerial remote wire and that is why the amp turns off when cd is selected.
Change the amp remote over to the correct wire on the deck and it will work properly.
Your deck should have 2 remote wires;
1 for amp etc
1 for aerial.
If it doesnt have the second remote wire - connect the amp remote the the accecories wire behind the deck.
Posted on: 2005/3/4 10:14
