1970 datsun
Does anyone know anything about 240z ignition? i cant get any spark from the coil, ive replaced with a working one but still nothing..anyone know how to trouble shoot and lead back to the source? the inside wiring is a mess with alot of previous butchery done, quarters in the fuse holder..etc. etc...I know this is a 1200 site but any help would be super, thanks alot..
Posted on: 2005/3/29 0:20
Re: 1970 datsun
From Dallas TX
www.classiczcars.com
You'll get the help you need there. But wait till tomorrow as it's down for upgrades right now. Good luck
Michael
Posted on: 2005/3/29 0:33
Re: 1970 datsun
From Sydney, Australia
Thanks for dropping by to visit.
The coil is fed by one of two 12V supplies.
The first is a direct 12v (for hottest spark) at start position, and about 9v when engine is running. (Assuming no alternator is connected, and pushing these figures to 12v and 14.4v respectively)
There've been too many backyard electricians who have made it 12V in both ignition switch positions to attempt to improve ignition performance. This will burn out the coil..so don't think about it.
- Disconnect the starter motor (black/yellow) wire so that the engine doesn't crank.
- Put a voltmeter across the terminals of the coil
- Turn key to ignition position, look at voltmeter for voltage. Should be about 9V
- Turn key to start position (will need to hold it on) and look at voltmeter, should be 12V.
This is testing that the coil is wired up properly to the ignition ballast resistor.
ps. quarters in the fuse holders is asking for melted wiring and dodgy connectors. Double check that all of the wiring, and connectors are in good condition. If they are stuffed, you'll have to either look for a new loom, oir wire up the engine/dash looms yourself.
ps. remember to reconnect starter wire when you are done. Also ..get rid of the Z-car and buy a 1200
Posted on: 2005/3/29 3:38
