Re: track width
sedan front track 124cm - rear track 125cm
coupe front track 124cm - rear track 125cm
Taken from NSW RTA Guidelines ;
Where non original axle or suspension components are fitted, the offset of the wheel in relation to the axle or stub axle assembly used shall not be increased by more than 12.5mm each side of the vehicle based on the specifications
of the axle components used. If an axle assembly is shortened then the track width limit is taken as the axle
manufacturers original track dimension, less the amount the assembly has been narrowed, plus 25mm.
I dont know if VicRoads include this clause in their guidelines?
But basically if you are useing struts from a different vehicle - the wheel track allowable now goes off the donor vehicle minus the measurement the struts where brought in when fitted to the new vehicle. This means it is infact possible to increase track by more than the standard amount aslong as you still meet the before mentioned criteria like " no fouling on vehicle etc.
Posted on: 2005/4/18 9:46
Subject Poster Date
     track width Anonymous 2005/4/17 15:27
       Re: track width phunkdoktaspok 2005/4/18 9:46
         Re: track width Anonymous 2005/4/18 10:52
