Re: R31 skyline struts into datsun 1200 ute??
From Melbourne, Australia
whats the benefit over a stanza strut with upgraded brakes???
or is it just that you dont need to upgrade the brakes???
single piston....hmph..i have four...hehe
just being silly yeah it would be good to get the strut cause it comes with vented discs straight off but sounds like a lot of work against the stanza strut that will bolt straight up
Posted on: 2005/5/19 3:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Melbourne Vic
you are right RC, but if you were up for a bit of work and wanted to customise your cars ride height and camber and castor with the addition of being able to run bigger rims because of the stub axle angle then this would be a good strut to start with. the brakes are good too.
if you wanted a lot less hassle the stanza sounds like a goer. dunno what the cost difference would be? i wanted to do it for the wheel choices and the brakes. $110 complete for the pair from a wrecker and where you go from there is up to you.
Posted on: 2005/5/19 8:40
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Quite a regular
tnanks guys this has been a really good thread. i plan on buying a whole skyline because i can get the diff too, and anything else i want too use.
Posted on: 2005/5/19 9:40
« 1 (2)
