crank?
G'day all hows a goin?
i got a L20b with balanced crank, and new pistons and rods and ####.
but tthe block has a little bit of surface rust.
its been bored 1mm or somethin like that.
but i dont want to use that block
and i have a spare block.
how do i go about puttin the balanced crank and good pistons and #### into the other block. will it stuff the balancing? or will it all be sweet?
Posted on: 2005/5/24 10:56
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
Re: crank?
From Stray-ya
Nice avatar woodydat, I had to read it a couple of times before I got it
You should be sweet with the new block as long as you get it bored out to fit the pistons. You want to get your crank balanced to the pistons and rods you are using, but putting them in a different block shoudnt make any difference.
Posted on: 2005/5/24 11:09
Re: crank?
yeh the pistons and rods are all ballanced for each other. and the crank.
so it will be sweet to go into the new block. aand yeh i'll be getting it bored to fit the pistons so its all good.
and yeah its time for a new avatar i think its a little old.
Posted on: 2005/5/24 11:20
Re: crank?
From Stray-ya
First I'd seen of it, but I dont spend a lot of time here...... yet.
Posted on: 2005/5/25 11:25
Re: crank?
From WA
yep - spot on.
the block is there to hold all the balanced bits in place. you can swap blocks all you like and not affect the balancing at all.
whatchu got planned now...?
Posted on: 2005/5/25 14:19
