Browsing this Thread:
1 Anonymous Users
Re: A Series |
From Victoria
Hi J
Yep an A series auto box has a removable bellhousing. I used a alli case celica box so I'm not sure how the steel one will match up. The clutch I used for the first 2 years was a bog standard mum & dad clutch. I rang our clutch guy and told him I needed a Toyota clutch that suits a standard datto pressure plate and he obliged, cost $100. If you want message me and I can give you his details, he mailed it to me so he will do the same for you. The thrust bearing conversion was easy, no need to spend all that money at Dellows
Posted on: 2005/6/16 0:11
Re: A Series |
From Port Kennedy, Perth Western Australia
Hey there Clubman , PM sent. I take it your still using the cable set up ? I was thinking of fitting a hydrolic set up and re using the Celica clutch fork and thrust bearing ( there for no mods) and slave cyl if I can mount it properly.
J.
Posted on: 2005/6/19 6:12
