by sidedraught on 2005/7/2 12:50:18
The original post says its a blow through for a Suzuki G13
Crap! I'm retarded.
OK, original Q.
The 35-75psi regs you're seeing are for fuel injection. You can get a Malpassi Turbo Carb regulator that works with an EFI fuel pump & return line to supply more than enough fuel in a carb'd situation. Here's a diagram -->
Click thisYou need a return line is all, they can work with a carb pump IF it can hold enough pressure to cover boost AND the original static pressure
So proper arrangement is fuel pump, reg, carby - with a return line taking fuel back to the tank AND the boost reference plumbed into the carb box or turbo outlet or something pressureised without fuel.
Yes, the OE reg is redundant
Mechanical secondaries are gunna be the go with being force fed
BOV can be mounted anywhere on the pressurised side before the throttle butterflies - the box or the piping in other words. Theres a heap of conflicting theories about pre or post cooler BOV mounting, I prefer nearer the throttle buit that's me.
For a boost source, from a runner will do fine, remember the regulator needs a boost source BEFORE the throttle whereas the BOV needs one AFTER so they can't share. Your brake booster will need a 1 way valve in it BTW or you may find yourself without brakes!
Does this help?
