A14 boost
From Gold Coast, Australia
whats the Max/safe boost you can run on a brand new a14 engine with stock components?
Posted on: 2005/7/2 15:20
Re: A14 boost
From Christchurch NZ
This is a difficult question, because there are so many variables.
You say " brand new" a14. Do you mean freshly rebuilt?
If it was rebuilt, and the CR was about stock, and the carburation was set up right, I would say 5-8 psi, Maybe higher with better quality fuel.
Posted on: 2005/7/2 22:55
Forced Induction!
Re: A14 boost
yes the motor is built freshly with all brand new components. so with the standard CR (which is?) with all running to plan we could get close to 10psi safley? what fuel do you forced induction boys use in street cars?
Posted on: 2005/7/3 2:11
Re: A14 boost
From SA the place to boost
if tuned right you should be able to run up to 15 psi. just make sure it tunned by somebody that knows what they are doing on a dyno.
a mate of mine ran 13 pounds on a stock A15 for years.
Ive run 15-16 pounds on stock L blocks
Posted on: 2005/7/3 4:41
Stanza L20 Turbo
Bluebird Series 1 FJ20ET
Bluebird Series 3 TRX CA18DET
